Go to Post Baker, you certainly are a trouble maker. :) - Rich Kressly [more]
  #31   Spotlight this post!
Unread 27-01-2010, 18:18
ellisk ellisk is offline
FRC #1540
ellisk is on a distinguished road
Re: Black jaguars: not working
I tried switching to CANJaguar as well, and I still get the errors I had before (status == -57002). This was using the CANJaguar class using the 2CAN attachment.
  #32   Spotlight this post!
Unread 27-01-2010, 18:37
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
There was an update to the 2CAN plugin released just a day or two ago. Try updating that.
  #33   Spotlight this post!
Unread 27-01-2010, 23:18
FRC #1540
I tried the update (http://crosstheroadelectronics.com/2...2CANPlugIn.out) and it still doesn't work. This is very odd...
  #34   Spotlight this post!
Unread 28-01-2010, 09:38
ozrien's Avatar
ozrien ozrien is offline
Omar Zrien
AKA: Omar
ellisk,
I just to confirm where you are...
You are using wind river c++ with "latest" checked out code from firstforge, or the last file release (zip under the file release link)?
You have latest FRC_2CANPlugin.out file from ctr website.
FRC_2CANPlugin.out is in the "ni-rt/system" directory on the ftp server in the cRIO.
ni-rt.ini is modified so that ";FRC_2CANPlugIn.out" is IMMEDIETELY after FRC_NetworkCommunication.out.
Note that FRC_2CANPlugIn.out now should be before FRC_UserProgram (in the past releases it would have been after but that was incorrect, causing all sorts of problems).
And also have you successfully viewed the web dashboard in the 2CAN and have confirmed that the Jaguar ID for your jag is the same one used in the constructor of CANJaguar?
  #35   Spotlight this post!
Unread 28-01-2010, 10:56
Bryscus's Avatar
Bryscus Bryscus is offline
EE, CpE
AKA: Bryce B.
FRC #0180 (SPAM)
Bryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud of
Originally Posted by ozrien View Post
ellisk,
ozrien,
I've been using CAN control for over a couple weeks now, but I'm using the serial port. CANJaguar.h is necessary for the project to build. ellisk only shows 2CAN.h included. Could this be his/her problem?
- Bryce
P.S. ellisk, I would verify yourself that your Jaguars are set with the correct ID. Also, that they have the correct firmware. There are two firmware files, one for the black Jags and one for the gray Jags. TI just released a new version of the firmware, so you can take this time to reflash with the newest: http://www.luminarymicro.com/index.p...d&Itemid=59 1
P.S.S. Unless you just didn't show it, you're also missing START_ROBOT_CLASS(Spy); that comes after your class. If this line is not there, the cRio won't deploy your code. This line creates a new task with your program...
P.S.S.S. Here's an example of what my code would be using CAN over the serial port.
#include "WPILib.h"
#include "CANJaguar.h"
class Spy : public SimpleRobot
	CANJaguar *mtr;
public:
	Spy(void)
                mtr = new CANJaguar (5);  //or whatever ID you have set
		GetWatchdog().SetEnabled(false);
	void Autonomous(void)
	void OperatorControl(void)
		while (true) {
			mtr->Set(0.5);
			Wait(0.5);
The opulence of the front office decor varies inversely with the fundamental solvency of the firm.
  #36   Spotlight this post!
Unread 28-01-2010, 13:14
basicxman basicxman is offline
Emily Horsman
FRC #2200 (MMRambotics)
basicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant future
Send a message via AIM to basicxman Send a message via MSN to basicxman Send a message via Yahoo to basicxman
Make SURE you have toggled the Console Out DIP switch on the cRio. My team was having the exact same problem and it worked after toggling Console Out and a good ol' hard reboot.
  #37   Spotlight this post!
Unread 28-01-2010, 15:40
Bryscus's Avatar
EE, CpE
AKA: Bryce B.
FRC #0180 (SPAM)
That's a good point for everyone trying to use the serial port, but it shouldn't matter for the 2CAN interface.
- Bryce
  #38   Spotlight this post!
Unread 28-01-2010, 16:39
hm29168's Avatar
hm29168 hm29168 is offline
*poke poke*
FRC #2415 (WiredCats)
hm29168 is an unknown quantity at this point
We have been having a similar problem as ellisk. We have updated our Jaguars to the most current firmware (87) as well as our 2CAN (v.1.5) and have gotten the sample code to work. However, we can only move sporadically with error -52007 showing up on the target console. Likewise, the watchdog is flipping on and off sporadically. We are using 2CAN with gray Jaguars.
  #39   Spotlight this post!
Unread 28-01-2010, 18:14
#include "WPILib.h"
	CANJaguar *mtr;
public:
	Spy(void)
		while (true) {
			mtr->Set(0.5);
			Wait(0.5);
And because of the unified architecture, the exact same code will work with the 2CAN with no modifications (or even rebuilding) by simply changing which driver plugin is configured to load on startup. It may be good to get a baseline with serial so you know the robot code is OK, then switch to the 2CAN plugin and see if there might be a problem with it.
-Joe
  #40   Spotlight this post!
Unread 28-01-2010, 18:17
Which watchdog?
  #41   Spotlight this post!
Unread 28-01-2010, 18:49
Mike Copioli's Avatar
Mike Copioli Mike Copioli is offline
You make it pretty We make it dance
no team (Retired(3539, 217))
Mike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond repute
Are you able to view the dashboard? If the answer is yes, are your Jaguars showing up in the dashboard view? If they are, and there are no faults displayed, it is possible the issue is somewhere in the code. One thing that you could do is leverage the dashboard feature of the 2CAN. When you are in the dashboard view, verify the throttle values that your code is requesting. For example if you are requesting a throttle value of 1, the throttle value in the dashboard view for that Jaguar should be 100%. Try this and post your results. The next release of the firmware will contain more diagnostic features that will help users to pinpoint problems.
Mike Copioli
CTRE Hardware Engineer
http://www.ctr-electronics.com
Team 3539 The Byting Bull Dogs
2013 Michigan State Champions
Team 217 The Thunder Chickens
2006 World Champions
2008 World Champions
2009 Michigan State Champions
  #42   Spotlight this post!
Unread 28-01-2010, 19:33
FRC #1540
Update:
ozrien: Yes to everything.
I'm not sure what on the dashboard would appear for the Jaguar. However, everything looks dead (not seeing any relays, etc).
I also get error -63194 at the start when I run over the RS232 port, that is:
>>>ERROR: status == -63194 (0xFFFF0926) in InitJaguar() in C:/windriver/workspace/Spy/CANJaguar.cpp at line 32
  #43   Spotlight this post!
Unread 28-01-2010, 23:18
Dale's Avatar
Dale Dale is offline
Head Coach & Mentor
AKA: Dale Yocum
FRC #1540 (Flaming Chickens)
One other thing to add to ellisk's report. When using the BDC-COMM application over RS-232 via a PC we are able to control the Jaguar and it's attached motor. It was thrilling to see a motor actually move! That seems to indicate the problem is not a physical one, at least using RS-232.
I'm about ready to pull the plug, so to speak, on CAN. We'd really like to use the advanced features of Jaguars, and love the way it cleans up the board, but we also need to get on with things. Ellisk is one of the most talented programmers our team has ever had -- four years on the team, four years of CS classes, Intel Science Talent Search finalist, etc.
Do you folks have any final ideas???
  #44   Spotlight this post!
Unread 29-01-2010, 01:00
-63194 is kRIOStatusVersionMismatch. Update the Jaguar firmware.
-Joe
  #45   Spotlight this post!
Unread 29-01-2010, 08:21
-Joe
This makes sense. That explains the jittery behavior. Ellis I would not give up on CAN just yet. Try to verify the JAG firmware version number as 87 using either the 2CAN web dash or the BDC-com.
Mike Copioli
Serial to CAN Gateway in new Black Jaguars? dmcguire3006 Electrical 54 26-01-2010 07:32
Jaguars arent working yoavh360 Electrical 6 19-01-2010 17:20
Victors and Jaguars not Receiving Signal? excel2474 Electrical 1 12-02-2009 16:41
jaguars suddenly not working Mr. E Technical Discussion 1 07-02-2009 21:09
Jaguars working with 2.4 Ghz R/C NOV8R Technical Discussion 0 09-01-2009 16:15
