Go to Post User error is not the manufacturer's fault. - AdamHeard [more]
Unread 26-01-2010, 22:55
jamie_1930's Avatar
jamie_1930 jamie_1930 is offline
FRC #2228 (Cougartech)
Team Role: Student
jamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to behold
Autonomous Mode
Hey guys I'm wondering what eveyone's thoughts were on what is going to be a good autonomous mode this year, a couple weeks ago on FIRSTcast they talked briefly on how a good autonomous mode could make the match. So what has everyone been thinking?
Team 2228(FRC) - Drive Team Lead, Drive Coach, Mechanical Team
Team 3750(FTC) - Team Lead
2009
Team 2228(FRC) - Mechanical Team, Driver at RIT, and Hartford Regionals, and Drive coach at Ruckus
*Second Place at Ruckus
Team 3750(FTC) - Team Lead, and Drive coach at Clarkson Regional
*Second Place at Clarkson Regional
2008
Team 1930(FRC) - Worked on Mechanical, Electrical, and Programming.
Unread 28-01-2010, 15:44
Bill_B Bill_B is offline
You cannot not make a difference
FRC #2170
Bill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond repute
Re: Autonomous Mode
Since I'm replying first, I get to state the patently obvious: A good autonomous period is one in which the alliance scores 6 balls in the first 15 seconds, then heads toward the other side of their respective zones ready to contest possession of the balls which did not make it into a goal. As a corollary, each robot's autonomous mode must behave according to the zone in which is is placed. (Of all the miracles I least expect to see is a single autonomous program that can score in whichever zone it is placed.)
Unread 28-01-2010, 17:14
Austin2046's Avatar
Austin2046 Austin2046 is offline
Design, Strategy & Scouting Mentor
FRC #2046 (Bear Metal)
Austin2046 has a spectacular aura aboutAustin2046 has a spectacular aura about
Re: Autonomous Mode
Our team is hoping to be able to kick the 3 balls from the far zone into our zone if not into our goal. Then possibly climb the bump over into the middle zone.
A bot starting in the middle zone should kick their two balls but then maybe they should drive to block the tunnel. Not only blocking it from other robots but also from the returning balls going into the opponents zone.
There are alot of different things that could be done in autonomous, apart from crossing the center line. What will be interesting to me is how teams will coordinate their autonomous and line up their starting positions so that kicked balls from the far zone dont hit their alliance partner in the middle or close zone.
Also i hope robots planning on climbing the bumps during autonomous dont have the tendancy of flipping themselves.
Unread 28-01-2010, 17:19
cziggy343's Avatar
cziggy343 cziggy343 is offline
cziggy343
AKA: Chris Z
FRC #0343 (Metal-in-Motion)
cziggy343 has a reputation beyond reputecziggy343 has a reputation beyond reputecziggy343 has a reputation beyond reputecziggy343 has a reputation beyond reputecziggy343 has a reputation beyond reputecziggy343 has a reputation beyond reputecziggy343 has a reputation beyond reputecziggy343 has a reputation beyond reputecziggy343 has a reputation beyond reputecziggy343 has a reputation beyond reputecziggy343 has a reputation beyond repute
Send a message via AIM to cziggy343
Re: Autonomous Mode
I really hope that all teams at the very very least have multiple mode that will just move them out of the way of thier teammates trying to kick over them. At the very least... really, every team with a kicker should try to kick the ball in auto.
Diamond Bullet Studios Co-Founder
http://www.dbsgames.net/index.php
Unread 28-01-2010, 17:21
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Re: Autonomous Mode
This is far easier to accomplish by placing the robot near the centerline and not executing any autonomous mode at all.
Unread 28-01-2010, 17:22
cziggy343's Avatar
cziggy343
AKA: Chris Z
Re: Autonomous Mode
unless that robot is tall and a kicker in the far end can't quite clear it. otherwise, agreed.
Unread 28-01-2010, 17:31
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Re: Autonomous Mode
I don't really understand how a robot placed adjacent to the centerline would ever interfere with a kick aimed at the goal.
With some quick math (27ft field/2 = 14/5 ft., 14.5 ft.-6ft ball grid = 8.5 ft., 8.5ft / 2 = 4.25 ft.) I come up with the closest set of dots to the centerline being 4.25 ft. away. That means that a robot easily fits between the soccer ball and the centerline.
Given that you are kicking the soccer ball away from the centerline towards the goal (unless you really want to shoot across the field into a goal the opponent can block), a robot placed as close to the centerline as possible should never interfere with a kick that would otherwise be successful.
Unread 28-01-2010, 17:42
FRC #2170
Re: Autonomous Mode
I just realized I have been assuming that the alliance gets to place BOTH the robots and the balls (on a grid) in each of the three zones. (heading to confirm this in the rules) This means that there is such a thing as pre-autonomous strategy too.
Unread 28-01-2010, 17:54
DjMaddius's Avatar
DjMaddius DjMaddius is offline
AKA: Matt Smith
FRC #2620 (Southgate Titans)
DjMaddius is an unknown quantity at this point
Re: Autonomous Mode
I dont have a manual with me right now, but i believe we can place both where ever we want in the grid we select through out the alliance of teams.
Unread 28-01-2010, 17:58
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Re: Autonomous Mode
Relevant rules are <G08> and <G09>
<G08> ROBOT Starting Positions – Prior to the MATCH, each TEAM negotiates within their ALLIANCE to select one of the three starting areas for their ALLIANCE.
When the FIELD is viewed from the ALLIANCE STATION, the ROBOTS must be placed on the right side of the CENTER LINE in one of the following starting positions:
• In the far ZONE and in contact with the ALLIANCE STATION WALL and/or ramp.
• In the MIDFIELD and in contact with the farthest BUMP.
• In the near ZONE and in contact with the nearest BUMP.
<G09> BALL Starting Positions – Prior to the MATCH, each ALLIANCE is provided with six BALLS to be placed on the FIELD. The BALLS must be placed on a STARTING GRID location prior to the MATCH start. When the FIELD is viewed from the ALLIANCE STATION, the BALLS must be placed on the right side of the CENTER LINE, with one BALL in the near ZONE, two BALLS in the MIDFIELD, and three BALLS in the far ZONE. The BALLS must not be in contact with a ROBOT at the start of the MATCH.
Unread 29-01-2010, 02:35
PaW's Avatar
PaW PaW is offline
AKA: Paul W
FRC #1899 (Saints Robotics)
PaW has a spectacular aura aboutPaW has a spectacular aura about
Re: Autonomous Mode
Thinking exactly the same thing, given that there are no 'bonus points' for scoring in autonomous. Just get the robot ready for decent positioning when teleop starts.
Unread 29-01-2010, 10:11
sloteera's Avatar
sloteera sloteera is offline
AKA: Rafa
FRC #1860 (Cephatron)
sloteera has much to be proud ofsloteera has much to be proud ofsloteera has much to be proud ofsloteera has much to be proud ofsloteera has much to be proud ofsloteera has much to be proud ofsloteera has much to be proud ofsloteera has much to be proud ofsloteera has much to be proud ofsloteera has much to be proud of
Re: Autonomous Mode
Let me know guys:
My robot could cross trough tunnel in autonomous mode?
The rules says that you just can't cross totaly the center line, so I'm wondering that my robot can go to the other zone!!
That's right?
Unread 29-01-2010, 10:36
jamie_1930's Avatar
Team Role: Student
Re: Autonomous Mode
Originally Posted by sloteera View Post
Let me know guys:
That's right?
Yep you can go through the tunnel.
2009
2008
Unread 29-01-2010, 10:42
Josh Fox Josh Fox is offline
AKA: Foxy
FRC #0027 (Team RUSH)
Josh Fox has much to be proud ofJosh Fox has much to be proud ofJosh Fox has much to be proud ofJosh Fox has much to be proud ofJosh Fox has much to be proud ofJosh Fox has much to be proud ofJosh Fox has much to be proud ofJosh Fox has much to be proud ofJosh Fox has much to be proud ofJosh Fox has much to be proud of
Re: Autonomous Mode
To me, a good autonomous will, as stated above, at least attempt to score all the balls given to them in their respective zone, or at least get them to a teammate who can score.
I also like the idea of moving to the line so that as soon as tele-op begins you can try to take your opponents leftover balls.
Team RUSH Alumnus and Mentor, Mechanical Engineer
Last edited by Madison : 29-01-2010 at 13:59. Reason: removed off topic reference.
Unread 29-01-2010, 11:20
sloteera's Avatar
AKA: Rafa
Re: Autonomous Mode
And, thanks by the answer Jamie!
Last edited by Madison : 29-01-2010 at 13:59. Reason: removed reference to off-topic post
Autonomous Mode furiousgeorge Programming 7 05-02-2009 17:20
Autonomous Mode Fish2977 NI LabVIEW 5 24-01-2009 10:35
autonomous mode Stephanie Programming 2 25-01-2003 19:57
Autonomous Mode David Bryan Programming 1 21-01-2003 21:15
autonomous mode? bigwalt Technical Discussion 1 21-01-2003 01:14
