Go to Post Are you confused yet? - Andy Grady [more]
Unread 25-01-2010, 15:04
Kevka's Avatar
Kevka Kevka is offline
FRC #0975
Kevka is an unknown quantity at this point
How to set up custom dashboard for auto start
Hi,
I've come a long way today: From believing that we are supposed to provide something like "Widgets" to the FRC dashboard to the insight that "The Dashboard application is optional for teams." (FRC Controll System 2010 Manual Section 1 page 9). And that we are allowed to develop our own, custom Dashboard software. The only thing that isn't completely clear to me is how to have your custom Dashboard application auto loaded when starting the Driver account just as the original one is.
Best regards Kevin
Unread 25-01-2010, 15:12
Re: How to set up custom dashboard for auto start
If running local, the DS can launch an application/command line. By default it launches c:\Program Files\FRC Dashboard\Dashboard.exe. To change what it launches, this can be adjusted in the ini file stored in the public documents.
Greg McKaskle
Unread 26-01-2010, 10:56
SteveD SteveD is offline
FRC #0888
SteveD is an unknown quantity at this point
we made a new dashboard, and have all the vi's together, but how do we run it on this ini file? There arent any other ".exe's" for this new dashboard
Unread 26-01-2010, 11:09
sloteera's Avatar
sloteera sloteera is offline
AKA: Rafa
FRC #1860 (Cephatron)
sloteera has much to be proud ofsloteera has much to be proud ofsloteera has much to be proud ofsloteera has much to be proud ofsloteera has much to be proud ofsloteera has much to be proud ofsloteera has much to be proud ofsloteera has much to be proud ofsloteera has much to be proud ofsloteera has much to be proud of
Another way to start your customized Dashboard automatically is doing an Application in the follow directory:
Will be three files inside these directory: An .exe, an .ini and another that I can't remember now. You'll should switch these three files by the files that you will generate.
To generate a New Application you'll should click with a right button on Build Specifications then select Application.
Choose the files that you'll want have associated with your Dashboard so click in Build!
I think (or better, I'm sure) that the way of Greg describes is easier, but this way will be right too!
Hope that can help you with something!
Unread 26-01-2010, 12:45
sloteera's Avatar
AKA: Rafa
Oh, sure: you'll need keep the same name to the files, that means use at your files the follows names:
Dashboard.exe ;
Dashboard.ini ;
Dashboard.something_that_I_can't_remember_now
Unread 26-01-2010, 21:56
Trevor_Decker's Avatar
Trevor_Decker Trevor_Decker is offline
AKA: Trevor Decker
FRC #3504 (Girls of Steel)
Trevor_Decker is an unknown quantity at this point
Originally Posted by Kevka View Post
Hi,
Best regards Kevin
How do you create a new Dashboard?
- Trevor
Team 3504 - The Girls of Steel 2011 - Present
2012 Pittsburgh Regional Engineering Inspiration, and website awards
Team 1743 - The Short Circuits 2009 - 2011
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2010 Won Autodesk Animation Competition
2010,2011 Pittsburgh Team spirit award
Unread 26-01-2010, 22:06
sloteera's Avatar
AKA: Rafa
Just select a new Dashboard Project in the first menu of LV!
Maybe you'll should modify something on the CRio project!!
I sugest that you watch this video: http://www.lvmastery.com/TipJar2009-02-10
Unread 27-01-2010, 22:58
joshholat joshholat is offline
FRC #0930
joshholat is an unknown quantity at this point
If we create a new Dashboard VI, will we be able to interface with it through Java? Does the FIRST Java API have anyway to output stuff to the LabView dashboard, or do we need to add something to our dashboard project to do so?
Unread 28-01-2010, 17:41
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
Do everything the Tip Jar video tells you to do on the dashboard side of things, but for the robot, simply use the Dashboard class to send the same data format that you defined in the LabVIEW cluster. Look at the Dashboard Data Example in Java for... well... and example of sending dashboard data.
-Joe
Unread 28-01-2010, 18:04
bronxbomber92 bronxbomber92 is offline
FRC #1551 (Grapes of Wrath)
bronxbomber92 is an unknown quantity at this point
Does anyone know if the dashboard program has to be a LabView application? Can we just write an app in C++ or C#?
Unread 28-01-2010, 18:26
For the local dashboard, it just has to be an executable. You can write it in anything you want. It's not allowed to cover up the driver station portion of the screen. It probably should have UDP and/or TCP support if you want to support the typical dashboard features.
Unread 28-01-2010, 18:46
Great to hear :-D
Custom Dashboard writchie FRC Control System 7 02-03-2009 20:21
Custom Dashboard - Visual Basic Mike Lat Programming 3 23-01-2005 14:26
Custom Dashboard Executable ready for Download! archiver 2001 1 24-06-2002 01:01
Custom Dashboard code for LabVIEW ready for download. archiver 2001 3 24-06-2002 00:49
Auto-Archive Set to 14 archiver 2000 0 23-06-2002 22:42
