Go to Post Save the frustration for build season. :p - Brian C [more]
Unread 27-01-2010, 18:04
Back @ it again with the white vans
AKA: Brandon Liatys
FRC #2180 (Zero Gravity)
2495's Kicker
http://www.youtube.com/watch?v=e_Dad...safe_search=on
any comments? What do you guys think?
Unread 27-01-2010, 18:11
The Reaver The Reaver is offline
FRC #2840
The Reaver is an unknown quantity at this point
Re: 2495's Kicker
That is INSANE. How are you planning on controlling the ball speed, though?
mikelowry mikelowry is offline
FRC #1771 (N.G.R.)
mikelowry is a name known to allmikelowry is a name known to allmikelowry is a name known to allmikelowry is a name known to allmikelowry is a name known to allmikelowry is a name known to all
Re: 2495's Kicker
Does it have to be spun up to speed when the ball hits it to get full distance? Or can you possess a ball and shoot it at will?
2008 Xerox Creativity Award - Championships
2009 Rockwell Automation Innovation in Control award - Peachtree
2009 GM Industrial Design Award - Palmetto
2009 Palmetto Champions <1771 2415 21>
Unread 27-01-2010, 18:13
Darth Pbal's Avatar
Darth Pbal Darth Pbal is offline
AKA: Paul Ronquillo
FRC #2375 (Biohazards)
Darth Pbal has much to be proud ofDarth Pbal has much to be proud ofDarth Pbal has much to be proud ofDarth Pbal has much to be proud ofDarth Pbal has much to be proud ofDarth Pbal has much to be proud ofDarth Pbal has much to be proud ofDarth Pbal has much to be proud ofDarth Pbal has much to be proud ofDarth Pbal has much to be proud of
Re: 2495's Kicker
Great kicker. My only concern would be how to incorporate that onto the robot and still not have any problems. You should use that but have a something to control how fast it spins. That way, if you're close to the goal, you spin slower so it doesn't like fly out of the arena and get you guys in trouble.
-Go Team 2375!
Darth Pbal
Unread 27-01-2010, 18:21
AKA: Brandon Liatys
Re: 2495's Kicker
Its run off a drive motor so its 100% controllable. We found that .6 of the 1.0 gives us the most distance (Programmer talk...), any higher makes the ball just go up. About .3 is enough to kick it short into the goal. It does have to be spun up to speed which is why we'll probably end up "dribbling" the ball (kicking it a short distance, following it, and kicking again). The power is for the autonomous we plan on trying to start at the far end and use omni wheels to kick all 3 balls to the other side.
Unread 28-01-2010, 18:10
infocus infocus is offline
infocus is an unknown quantity at this point
Re: 2495's Kicker
We prototyped a hand powered version of this and really liked the idea, but we thought it would be hard to utilize without violating <G30>. How are you guys approaching this?
Unread 28-01-2010, 19:00
AKA: Brandon Liatys
Re: 2495's Kicker
it would't extend out, the ball would go in. From what I understand, the ball can travel inside the robot a maximum distance of 3".
Unread 28-01-2010, 20:07
Bill_B Bill_B is offline
You cannot not make a difference
FRC #2170
Bill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond repute
Re: 2495's Kicker
So the kicker wouldn't extend beyond the frame perimeter?
Unread 28-01-2010, 20:16
Re: 2495's Kicker
How do you plan on the ball not hitting your bumper? If your kicking it from 3 inches in, you've got 6 inches of material to avoid. Your kick seemed like it had a very high angle to begin with.
Kicker Help? infocus Technical Discussion 23 30-01-2010 15:28
kicker idea input windell747 Technical Discussion 19 26-01-2010 16:06
FRC1577 Kicker Teaser NirZiv Robot Showcase 0 23-01-2010 06:01
Hybrid Kicker falconmaster General Forum 15 20-01-2010 14:27
kicker or linear accelerator? John G Technical Discussion 7 20-01-2010 13:48
