Go to Post If we all keep our "secrets" about our robots, the rest of us don't learn as much. - Rick TYler [more]
Unread 28-01-2010, 19:15
Re: Programming 24v relay
Rather than save the example under your Robot project, you probably want to want to open both and copy/paste the solenoid code into your source. The first thing to do is to open Begin where you'll open and store the solenoid refnums.
Then in your code where you want to change the solenoid state, read the refnum and update the state by setting the solenoid, like in the example. Finally, in Finish, read and close.
Note that you may want to build a subVI that updates the state so that you can do it in different places in your program, auto, tele, etc.
Greg McKaskle
Programming 2 buttons for a relay team877 NI LabVIEW 15 18-02-2011 00:18
Programming a relay in C++ Kage C/C++ 2 10-01-2009 17:51
Easy C Relay Programming Team_486 Programming 1 26-03-2007 15:01
Pneumatics (Spike Relay, Solenoid etc.) Programming oceansidehs Programming 8 10-02-2007 13:58
Relay Programming Questions... comwiz7 Programming 11 21-02-2006 13:04
