Go to Post I think a 100% student-run team is as good as a school taught by your peers. - [more]
Unread 25-01-2010, 19:53
hurtzmyhead hurtzmyhead is offline
AKA: Shane
FRC #3021 (The Agency)
hurtzmyhead is a glorious beacon of lighthurtzmyhead is a glorious beacon of lighthurtzmyhead is a glorious beacon of lighthurtzmyhead is a glorious beacon of lighthurtzmyhead is a glorious beacon of lighthurtzmyhead is a glorious beacon of light
Axis Camera Power polarity
Don't ask me how, but our programing team broke the power jack connected to the axis camera, Rather than mount it back on they want to wire it up directly to the power distribution board. Ive in the threads that a radio shack model of the power adapter is available, from which i could get the polarity of the smd pads, but with extensive searching i could not find it. Could someone give me either the model number or the polarity of these pads?
Unread 25-01-2010, 20:27
Re: Axis Camera Power polarity
I don't quite understand the question, so I'll give you the answers to questions I do understand.
The camera power connector has positive in the center and negative on the outside. The Axis 206 camera's frame is electrically connected to the negative side of the power input. The separate camera power supply that came in our Kit of Parts last year was part number SA106A-0512-6.
Unread 28-01-2010, 20:20
Lord Byron's Avatar
Lord Byron Lord Byron is offline
AKA: Tim Sebek
FRC #0538 (Dragon Slayers)
Lord Byron is an unknown quantity at this point
we have a similar problem, the small black box which houses the connection inside is "loose" and the connection is unreliable. we're considering making a direct connection as well. could you let us know if it works for you?
You have a ramen doctor in your secret ramen base!?!
Unread 28-01-2010, 23:40
Gary Bonner Gary Bonner is offline
FRC #3974
Gary Bonner has a spectacular aura aboutGary Bonner has a spectacular aura about
We had the same problem and made the direct connection. We haven't had any problems so far.
Unread 03-02-2010, 09:21
Lord Byron's Avatar
AKA: Tim Sebek
We just finished with connecting the power directly and everything seems to be working.
Axis Camera 206 Power Connection Matt2081 Electrical 7 24-01-2010 15:51
Java/Netbeans Camera Code for Classmate PC and Axis Camera joshholat Programming 1 23-01-2010 14:59
Axis Camera ehochstein Programming 2 21-02-2009 00:16
axis camera power cable falling out.. dani190 Electrical 7 19-02-2009 13:55
Need help with Axis 206 Power Adapter dipmeinaluminum FRC Control System 1 21-01-2009 20:01
