Go to Post You know this crazy ChiefDelphi... nothing but useless information and kids ranting about pizza. - Amanda Morrison [more]
Unread 28-01-2010, 19:15
Lakedaimon's Avatar
Lakedaimon Lakedaimon is offline
FRC #3012 (Spartans)
Lakedaimon is an unknown quantity at this point
"Emergency Stopped" message won't go away
Soryy if this is covered somewhere else, I searched and could not find anything on this.
We have been through multiple installation process on the driver station, we finally see the compass, everything is green, we are reading battery voltage - so I think we are getting close. However, the driver station says "Emergency Stopped" and we cannot enable anything. What are we doing wrong?
Firmware is the most expensive thing in the universe. - Jack G. Ganssle
Unread 28-01-2010, 19:38
Back @ it again with the white vans
AKA: Brandon Liatys
FRC #2180 (Zero Gravity)
Re: "Emergency Stopped" message won't go away
If someone hit the button: Turn off robot and turn back on.
If not: I have no idea, check your code? I dont know if the watchdog does that as I have never been shut down by it. Try running the default code.
Not sure what it says if the button isnt plugged in, but make sure its in also.
Unread 28-01-2010, 19:48
Lakedaimon's Avatar
Yep, that worked. It was still E-stopped through the driver station update and multiple PC reboots, but it's fine now.
I still can't get the camera working though. Went through the setup process multiple times, and I'm updating the Driver Station for the third time now, but I can't see it on the Driver Station.
Unread 28-01-2010, 21:55
AKA: Brandon Liatys
have the code running for the robot and it should work, did for us.
Unread 28-01-2010, 22:14
basicxman basicxman is offline
Emily Horsman
FRC #2200 (MMRambotics)
basicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant future
Send a message via AIM to basicxman Send a message via MSN to basicxman Send a message via Yahoo to basicxman
For reference once the E-Stop button is pressed, you'll need to hard reboot your robot no matter what. For more details read the control systems manuals.
Unread 28-01-2010, 22:29
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
You must either run code from a developer computer or permanently deploy code to the CRIO for a picture to be visible on the driver station.
Unread 28-01-2010, 22:41
Lakedaimon's Avatar
To verify I understand what you mean - we have loaded the Java version of the bench test code from the Driver Station to the cRio and are using that to test with. I sounds like you are saying that the camera image will not display on the Driver Station with this configuration.
It sounds like now we need to load another project (TrackerDemo?) to get the camera to display on the Driver Station. Is that correct?
Thanks for the help!
Unread 29-01-2010, 01:01
Tom Line's Avatar
I'm sorry - I can't comment on the Java configuration. I know in Labview for the camera picture to be visible, you have to "run" the code from a developer computer, or permanently deploy it to the CRIO. The vision components come as a standard piece of the default framework that everyone uses.
Sorry I can't help more - hopefully one of the Java programming teams sees the post.
Unread 29-01-2010, 14:50
Can you browser to the camera if you hook it directly to the Classmate?
I assume you setup the camera with an FRC/FRC account/password?
Unread 29-01-2010, 17:08
Lakedaimon's Avatar
We loaded the CircleTrackerDemo code into the cRIO and the camera feed showed up on the DS, so we are on our way (at least for now.)
Thanks for all the great input!
Unread 08-08-2012, 00:46
marley4070's Avatar
marley4070 marley4070 is offline
The Guitar Kidd
FRC #2439 (Bearbotics)
Team Role: CAD
marley4070 is an unknown quantity at this point
We were getting that same problem regarding the emergency stopped message on our driver console. I saw that everyone was mentioning things about problems with the code? I was wondering if anyone could help me diagnose what kind of problem that would be. Like, what would be the problem with the code that would produce that problem?
Help would be much appreciated!
Thanks!!!
Unread 08-08-2012, 07:50
Once your robot is E-Stopped it can only be cleared by turning the robot off.
E-Stop is designed that way.
The Driver Station space bar E-Stops the robot now, so avoid using it.
It's easier to Disable your robot using the Enter key.
Unread 08-08-2012, 09:12
rg_09 rg_09 is offline
FRC #2604
rg_09 is an unknown quantity at this point
If you have issues after successfully setting up the camera and then doing a power cycle, it is because you are using the wrong version of the Camera Setup utility. Get and install the update from the NI site and it will correct this problem. The original version of the setup utility released around 2012 kickoff caused this behavior.
Unread 08-08-2012, 20:10
Gigakaiser Gigakaiser is offline
AKA: Brandon Hjelstrom
FRC #0987 (High Rollers)
Gigakaiser has a brilliant futureGigakaiser has a brilliant futureGigakaiser has a brilliant futureGigakaiser has a brilliant futureGigakaiser has a brilliant futureGigakaiser has a brilliant futureGigakaiser has a brilliant futureGigakaiser has a brilliant futureGigakaiser has a brilliant futureGigakaiser has a brilliant futureGigakaiser has a brilliant future
If you're using the actual E-stop button on your driverstation:
I was stuck on this issue for hours one day during build season. (we switched laptops, powercycled multiple times, etc) This may sound idiotic but the corner of our driverstation was slightly pressing the e-stop button the entire time.
FRC Team 987 - It's not enough
Unread 11-08-2012, 17:32
Tom Line's Avatar
HA!
We tried to use our E-stop button about a year ago (the old style). We discovered that I had been a little over-zealous hot-gluing it down. Evidently, we had gone to multiple competitions with an E-stop button that was about as useful as a paperweight.
ON another note (to National Instruments), PLEASE PLEASE get the e-top button off the spacebar. Trying to type on the drive station and constantly having it e-stop the robot is beyond annoying. Move it to the escape key. It's rarely hit during normal use.
"Demo Stamp not found" error message Gatto Programming 1 07-02-2007 23:17
The "Godfather of Soul" Passes away Heretic121 Chit-Chat 5 27-12-2006 17:06
"The Power of a Positive Team" Message Joe Matt General Forum 2 04-04-2005 09:48
"Thunderbirds" Vs. "Team America" Which one will rule the box office? Elgin Clock Chit-Chat 3 07-09-2004 19:53
Why would I "subscribe" to a message thread or a forum? Joe Johnson CD Forum Support 4 07-06-2001 22:07
