Go to Post Stacking totes on end; Gives you extra height, alas; Topples with a sneeze. - BethMo [more]
Unread 28-01-2010, 22:16
Team1710's Avatar
Team1710 Team1710 is offline
FRC #1710
Team1710 is an unknown quantity at this point
file collisions
I am trying to permanently download code onto the Crio using the base code given by FIRST but when I go through the process of downloading the code, it is telling me that I am getting errors due to file collisions. Is anyone experiencing this issue or know how to fix it?
Unread 28-01-2010, 22:18
JBotAlan's Avatar
JBotAlan JBotAlan is offline
Forever chasing the 'bot around
AKA: Jacob Rau
FRC #5263
JBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond repute
Send a message via AIM to JBotAlan Send a message via Yahoo to JBotAlan
Re: file collisions
I haven't heard of this issue before, but I'm certain that you can run the cRIO updater software and specify that you'd like it to format the filesystem. There won't be any collisions if there's no files!
Aren't signatures a bit outdated?
Unread 29-01-2010, 01:05
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Re: file collisions
This is not an error.
Any time you permanently deploy the program to the Crio, it sees the program that is ALREADY deployed there and warns you. It's essentially the same thing as the Windows warning that tells you the file already exists before you overwrite it.
Good luck!
How to use the data obtain in one C file to another C file? tommy_chai Programming 8 11-01-2008 02:17
"Error.MCP" file after HEX file trans iwdu15 Programming 1 24-01-2007 20:05
Help! making an inventor file into an autodesk file kjhobin Inventor 5 19-03-2006 23:04
Midfield Collisions Swampdude General Forum 36 31-01-2005 23:51
How do we convert a modified user routines file into a valid .HEX file HuskieRobotics Programming 13 28-02-2004 12:12
