Go to Post We moved-ish mostly, in a direction or two. - Siri [more]
Unread 28-01-2010, 22:53
Darth Pbal's Avatar
Darth Pbal Darth Pbal is offline
AKA: Paul Ronquillo
FRC #2375 (Biohazards)
Darth Pbal has much to be proud ofDarth Pbal has much to be proud ofDarth Pbal has much to be proud ofDarth Pbal has much to be proud ofDarth Pbal has much to be proud ofDarth Pbal has much to be proud ofDarth Pbal has much to be proud ofDarth Pbal has much to be proud ofDarth Pbal has much to be proud ofDarth Pbal has much to be proud of
Limiting the Cylinder stroke
Okay so the deal is that I've heard a lot about increasing the pushing power of a pneumatic cylinder by limiting how far it can pull back. I want to try that but I don't know how I can do it. Can someone tell me how I can get that done?
-Go Team 2375!
Darth Pbal
Unread 28-01-2010, 23:28
jamie_1930's Avatar
jamie_1930 jamie_1930 is offline
FRC #2228 (Cougartech)
Team Role: Student
jamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to behold
Re: Limiting the Cylinder stroke
I'm pretty sure you should be able to add in some physical stops for it. Or am I on the wrong track? What exactly are you trying to do?
Team 2228(FRC) - Drive Team Lead, Drive Coach, Mechanical Team
Team 3750(FTC) - Team Lead
2009
Team 2228(FRC) - Mechanical Team, Driver at RIT, and Hartford Regionals, and Drive coach at Ruckus
*Second Place at Ruckus
Team 3750(FTC) - Team Lead, and Drive coach at Clarkson Regional
*Second Place at Clarkson Regional
2008
Team 1930(FRC) - Worked on Mechanical, Electrical, and Programming.
Unread 28-01-2010, 23:39
Darth Pbal's Avatar
AKA: Paul Ronquillo
I'm trying to take my Cylinders and increase their force that they can give. And I know you have to put something on the shaft or something so that when it retracts it can't come back all of the way and it then acts like another part where some air pressure can be stored. This shortens the stroke, but increases it's power. I know you have to limit it from retracting all the way but I can't think of anything off the top of my head that would be able to stay on for a long time while it's being powered.
-Go Team 2375!
Darth Pbal
Unread 28-01-2010, 23:41
RyanB RyanB is offline
FRC #0360
RyanB is an unknown quantity at this point
PVC pipe on the end has worked in the past for us when we need to limit the stroke.
Unread 29-01-2010, 00:01
Matt H. Matt H. is offline
Long Distance Mentor
FRC #1726 (N.E.R.D.S.)
Matt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond repute
From your posts I believe you are talking about preloading the cylinder.
To do this you need to hold the cylinder partially extended and then fill the cylinder.
In an optimal configuration the piston will be extended ~.3-.4* the length of cylinder.
Most teams hold the piston in place using some kind of latch. Team 842 uses a standard gate latch and U bolt as part of their configuration while other teams use quick releases designed for water sports etc.
On the physics:
This does not increase the maximum force provided by the cylinder. That will always be given by system pressure*area.
Preloading the cylinder increases the system's energy output by maintaining that force over a longer distance. (Work is force integrated over distance).
Here are some useful links:
Regarding safe kickers:
http://www.chiefdelphi.com/forums/sh...ad.php?t=80679
Regarding the math/physics:
http://www.chiefdelphi.com/forums/sh...ad.php?t=81145
An Example (with photos!):
http://www.chiefdelphi.com/forums/sh...ght=842+kicker
I hope this helps and would be more than happy to answer any additional questions you might have.
Unread 30-01-2010, 12:41
For a given kicker design, preloading gives a higher force over the same distance, yielding more energy.
Consider two identical robots which both have mechanical latches to hold the kicker in the "armed" position, and which both have the piston in the 35% extended position when in the armed position.
The only difference between the two robots is that Robot A pre-charges the cylinder with 60psi, whereas Robot B does not.
The piston in Robot A and the piston in Robot B both travel through the same stroke when kicking.
Because of the pre-charge, the pressure in Robot A's cylinder will be greater than the pressure in Robot B's cylinder at the start of the kick (and perhaps even throughout the entire kick).
The greater pressure results in greater force, and the greater force acting over the same distance results in more energy in Robot A's kick.
Now remove the constraint that the two Robots are identical. Instead, Robot B's kicker design is modified to provide a longer stroke, by retracting the piston further.
Now it isn't so obvious any more which system will delivery more kicking energy. For a very interesting discussion of this situation, see vamfun's post#12 in the following thread:
His conclusion, in a nutshell, is that it is better to use the full stroke (and not pre-charge) the small-bore cylinders, whereas it is better to pre-charge (and not use the full stroke) for large-bore cylinders. The reason for this ultimately traces back to the 1/8" .32 valve restriction. Note that the conclusions in that post are based on using greater stroke for the non-charged scenarios (as in the "non-identical" kicker design scenario above). Note also that the conclusions in vamfun's post are based on a set of operating assumptions (especially load) that may be different in your kicker design.
Last edited by Ether : 30-01-2010 at 15:09. Reason: added detail for clarification
Unread 30-01-2010, 13:45
kramarczyk's Avatar
kramarczyk kramarczyk is offline
is getting his kicks.
AKA: Mark Kramarczyk
FRC #3096 (Highlanders)
kramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond repute
You must spread some Reputation around before giving it to Matt H. again.
<edit> Ether does a nice job of explaining the pressure effects over the length of the stroke. Matt's links pertain to the pre-charging required to get around the flow limits of the system that enable those higher pressures. Both pieces are required to maximize power out of the cylinder. Work is equal to force over distance (W=F*d), which is what Ether is maximizing. Power is work divided by time (P=W/t); Matt is trying to reduce the time the work is done in.
Mark
Brick walls are for other people. - Randy Pausch
Last edited by kramarczyk : 30-01-2010 at 15:23. Reason: post above edited to add clarifying detail
Going disabled changes the cylinder position purduephotog Pneumatics 5 18-02-2008 07:55
calculating cylinder length from stroke nighthawk0501 Pneumatics 13 14-01-2008 15:33
limiting voltage to the speed controller team877 Programming 7 06-02-2007 16:28
3/4" bore x 1/2" stroke Bimba Cylinder model sanddrag Inventor 5 16-01-2006 22:14
Limiting the Strategy of the Game Andy Grady Rules/Strategy 20 04-02-2003 17:55
