Re: How do you get Tank Drive working?
The default code doesn't switch between tank and arcade even though the manual says it does.
The tank drive example should work, but there several ways to download a test program and run it. Here's one way:
This program will stop running when you stop LabVIEW, switch Classmate user accounts, or reboot the robot. You can also change the default robot project to use tank drive by replacing and rewiring. If you want to try this and need directions let us know. Last edited by Mark McLeod : 29-01-2010 at 10:15. Reason: "switch Classmate user accounts" |
If you continue to have issues, private message me. We'll be in our workshop all day Saturday, and we're about 40 minutes from you. You can come over and we'll walk you through how to set it all up.
Could you get me directions on how to change the default robot project to use tank drive by replacing and rewiring?
-2654 |
I'll assume you know the basics of LabVIEW programming - how to wire, how to get around the palettes.
You need to do two things:
| Tank Drive vs. Omni Directional Drive | jamie_1930 | General Forum | 9 | 24-01-2010 22:50 |
| Please Help, Don't Know How to Implement Tank Drive in LabView | CVassos | NI LabVIEW | 5 | 24-12-2008 16:55 |
| How to get robot to drive straigth using shaft encoders | eccmaster | Programming | 5 | 02-02-2008 23:50 |
| how do you get new members??? | jackie Ha | Team Organization | 15 | 09-11-2006 22:15 |
| How do you get ready for Regionals? | Kyle Love | Chit-Chat | 11 | 13-03-2005 22:49 |
