Originally Posted by Ed Law
Team 842,
That is an awesome kicker design. I now understand how one can use springs (surgical tubes) to assist to get the piston come out faster. I also learned about pre-charging (pressurizing) and how you use the gate latch to hold it.
Can you tell me in your set up, if the maximum distance by doing everything you are doing is 20 feet, what is the distance if you do not pressurized the kicking cylinder and just activate the solenoid valve? Did you also try to pressurize the kicking cylinder but take out the elastic cords. We are very behind right now and will not have time to try out all these things. Any help from any team will be appreciated.
Right now, we are using only a pneumatic cylinder to power our kicker and it's not working too well (about 1.5 ft max distance in the air). We're going to try pressurizing with a gate latch this weekend and try and add some surgical tubing. Hopefully we'll get a similar result as what's in the video.
