| Thread Tools |
Rating:
Display Modes |
#31
Re: 842 Kicker On Bot
Do you do that by controlling how much air it gets? timing the opening/closing of the solenoid valves?
#32
In short, the amount of time the valve is open varies the amount of strength we use to make contact with the ball. |
#33
Team 842,
That is an awesome kicker design. I now understand how one can use springs (surgical tubes) to assist to get the piston come out faster. I also learned about pre-charging (pressurizing) and how you use the gate latch to hold it. Can you tell me in your set up, if the maximum distance by doing everything you are doing is 20 feet, what is the distance if you do not pressurized the kicking cylinder and just activate the solenoid valve? Did you also try to pressurize the kicking cylinder but take out the elastic cords. We are very behind right now and will not have time to try out all these things. Any help from any team will be appreciated. Last edited by Ed Law : 29-01-2010 at 00:10. |
#34
Using the elastics doubled our range. What we did was use as much elastic force as possible while still being able to retract the cylinder pneumatically. |
#36
2. With just air no pre-pressurizing and locking it at 4" before releasingwe get about 5 feet- to 7 feet 3. with pre-pressurizing we get 18 to 20 feet |
#37
Yeah, we'll be there with both our bots. A large portion of our team will be missing due to other school stuff...
| 842 finalist to build a Space Bot | N7UJJ | FIRST In the News... | 7 | 15-03-2010 21:49 |
| 842 Final Kicker Desgin | kE7JLM | General Forum | 34 | 27-01-2010 13:41 |
| pic: 842 Falcon Robotics BreakAway Bot img.3 | kE7JLM | Extra Discussion | 14 | 21-01-2010 15:10 |
| pic: 842 Falcon Robotics BreakAway Bot img.2 | kE7JLM | Extra Discussion | 15 | 21-01-2010 12:43 |
| info on 997 bot or 254 bot please! | u2andllamasohmy | Motors | 16 | 11-11-2007 23:33 |
