Go to Post Baker, you certainly are a trouble maker. :) - Rich Kressly [more]
Unread 29-01-2010, 01:13
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Re: How do you get Tank Drive working?
If you continue to have issues, private message me. We'll be in our workshop all day Saturday, and we're about 40 minutes from you. You can come over and we'll walk you through how to set it all up.
Unread 29-01-2010, 19:08
Kramer 2654 Kramer 2654 is offline
FRC #2654
Kramer 2654 is an unknown quantity at this point
Post Re: How do you get Tank Drive working?
Could you get me directions on how to change the default robot project to use tank drive by replacing and rewiring?
-2654
Unread 30-01-2010, 00:04
I'll assume you know the basics of LabVIEW programming - how to wire, how to get around the palettes.
You need to do two things:
  1. Add another joystick for tank drive
  2. Switch Arcade Drive to Tank Drive
First open/close the joystick:
  • In Begin.vi copy the creation of Joystick 1 and paste it.
  • Change the new joystick open to another USB port
  • Give the new joystick a descriptive new name. e.g., "joystick 2"
  • Wire the error output to the little Build Array box. It can be expanded to expose a new node for wiring.
  • In Finish.vi copy the code for joystick 1 and paste it.
  • Change the name to "joystick 2"
Next switch to Tank Drive:
  • In Teleop.vi, in the inner case statement box select the False case.
  • Remove the axis 1 (x) wire leading to the Arcade Drive
  • Right-click on Arcade Drive, select Replace -> RobotDrive Palette -> Tank Drive
  • Copy the Joystick Get and the unbundled axis box and paste it.
  • Wire the new axis 2 (y) to the Left Axis Value node on Tank Drive
  • Now the new joystick should be added to the Joystick Read vi if you wanted to maintain the style used here, but I'm going to fall back to a simple approach and just have you add it to the left side of the block diagram.
  • Add a Joystick RefNum Registry Get.vi (the one that looks like the # Drive icon) on the far left.
  • Add a constant to the "refnum name" input node and give it the name of your second joystick
  • Wire the output JoystickDevRef through the two case statements to the Joystick Get you added.
Tank Drive vs. Omni Directional Drive jamie_1930 General Forum 9 24-01-2010 22:50
Please Help, Don't Know How to Implement Tank Drive in LabView CVassos NI LabVIEW 5 24-12-2008 16:55
How to get robot to drive straigth using shaft encoders eccmaster Programming 5 02-02-2008 23:50
how do you get new members??? jackie Ha Team Organization 15 09-11-2006 22:15
How do you get ready for Regionals? Kyle Love Chit-Chat 11 13-03-2005 22:49
