Go to Post "which came first, the hamster or the toad?" - dlavery [more]
Unread 29-01-2010, 04:05
windell747 windell747 is offline
FRC #2477
windell747 will become famous soon enoughwindell747 will become famous soon enough
spacer or no spacer for plaction wheel
Hi, We just purchased a set of plaction wheels from Andy Mark and realized that the sprocket that comes with the kit of parts fits, but if the chain were to run on the sprocket the links will touch the plastic hub of the wheel.
If seems that a spacer is required between the sprocket and the wheel. Have any of you had the same experience?
If so, do any of you know a place other than andymark that would sell spacers?
Thanks,
Windell
Unread 29-01-2010, 04:30
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: spacer or no spacer for plaction wheel
Hey Windell, long time no see/chat! Hope everything is going well with you and your team.
For a spacer for that, the AndyMark one is probably easiest, although you could also use individual ones such as part number 9510A742 from McMaster Carr.
You can also make some even just with basic tools. Cut some out of 1/4" polycarb with some hole saws, and print out a 1:1 scale template to drill the bolt holes. Just try to keep everything as centered as possible so your chain tension isn't affected when the sprocket rotates.
Unread 29-01-2010, 06:55
ttldomination's Avatar
ttldomination ttldomination is online now
Sunny
When using #25 Chain, you will need a spacer between the sprocket and the wheel, but you should be alright if you're using #35 chain.
I also recommend andymark for the spacers, but you can fabricate them out of almost anything.
1648: 2013-2014
5283: 2015
Unread 29-01-2010, 07:26
Jared Russell's Avatar
Taking a year (mostly) off
It depends on your sprocket diameter. The 22 tooth (#35) sprockets definitely need a spacer; the 28 tooth ones do not.
Unread 29-01-2010, 09:07
ajlapp ajlapp is offline
AKA: Anthony Lapp
None #0118 (Team RUSH and Robonauts)
ajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond repute
34 tooth is the smallest possible when using #25 chain on a plaction wheel.
Your best bet, purchase a $4 sprocket spacer from AM.
Anthony Lapp
FIRST Engineering Mentor
Owner/Operator 221 Robotic Systems
221 Robotics Systems - Quality Hardware, Made in the USA
RobotOpen
anthony@221robotics.com
Twitter us: @221RobotSystems
Team 1 --> 94 --> 68 --> 221 --> 857 --> 27 --> 118
Design Engineer/Fabricator and 17 year vet
Team Rush (FRC27) and Robonauts (FRC118)
Unread 30-01-2010, 09:13
Tony.Wu Tony.Wu is offline
Carnassial
AKA: Dave The Mechanic
Team Role: Animator
Tony.Wu is an unknown quantity at this point
Send a message via MSN to Tony.Wu
We just used a couple of nuts as the spacers.
Unread 01-02-2010, 02:12
FRC #2477
Awesome idea Tony! I didn't think about that. Thanks for the reply everyone!
Trailer Hitch Spacer HELP!!! robonerd13 Rules/Strategy 2 15-02-2009 20:49
Trailer hitch spacer info??? jph399 Technical Discussion 11 29-01-2009 00:27
Problem with BB gearbox spacer jskene Motors 2 10-01-2007 01:08
Nylon Spacer Size Laura 1547 Technical Discussion 2 22-01-2006 15:42
pic: Spacer....heh CD47-Bot Extra Discussion 4 15-03-2004 01:00
