Re: spacer or no spacer for plaction wheel
When using #25 Chain, you will need a spacer between the sprocket and the wheel, but you should be alright if you're using #35 chain.
I also recommend andymark for the spacers, but you can fabricate them out of almost anything. |
It depends on your sprocket diameter. The 22 tooth (#35) sprockets definitely need a spacer; the 28 tooth ones do not.
34 tooth is the smallest possible when using #25 chain on a plaction wheel.
Your best bet, purchase a $4 sprocket spacer from AM. |
We just used a couple of nuts as the spacers.
Awesome idea Tony! I didn't think about that. Thanks for the reply everyone!
| Trailer Hitch Spacer HELP!!! | robonerd13 | Rules/Strategy | 2 | 15-02-2009 20:49 |
| Trailer hitch spacer info??? | jph399 | Technical Discussion | 11 | 29-01-2009 00:27 |
| Problem with BB gearbox spacer | jskene | Motors | 2 | 10-01-2007 01:08 |
| Nylon Spacer Size | Laura 1547 | Technical Discussion | 2 | 22-01-2006 15:42 |
| pic: Spacer....heh | CD47-Bot | Extra Discussion | 4 | 15-03-2004 01:00 |
