Go to Post And now you know why we have a " No Karthik singing zone " north of the border. - Steve W [more]
Unread 23-01-2010, 00:23
jspatz1's Avatar
jspatz1 jspatz1 is offline
AKA: Jeff
FRC #1986 (Team Titanium)
jspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond repute
Send a message via AIM to jspatz1
Re: adjustable pressure regulator
Control system rules are not my area and I have not studied any changes for this year, but connecting outputs to a device such as an electronic regulator has always been prohibited in the past. We considered this exact same idea last year when looking for ways to vary our pneumatic catapult. The ruling was that the electronic regulator is an electromagnetic actuator just like a solenoid or prohibited servo or motor is, and therefore could not be used. Only kit motors, servos, and solenoid valves may recieve output signals, unless they have made a major change this year. I would study this carefully before proceeding.
Unread 23-01-2010, 00:34
Use one input solenoid and one exhaust solenoid, and adjust the kick by varying the on/off timing of the two in software. no pressure regulator necessary.
Unread 23-01-2010, 08:59
Was this a response from the Q&A? I would have to agree that it is a motor and therefore not a legal motor.
Unread 23-01-2010, 09:05
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Al, it was a response ot the Q&A but with the way they worded the question they got a different rule outlawing it.
Quote from 2009 Q&A
Modified PWM Signal
Posted by FRC1986 at 01/19/2009 02:26:38 pm
Is it allowed to use a modified PWM signal to control an electronic pressure regulator to control
pneumatics?
A low pass filter would be used to convert the 5v digital PWM signal into a 0-5v analog signal.
Re: Modified PWM Signal
Posted by GDC at 01/22/2009 06:41:00 pm
No. That would be a violation of Rule <R67>.
Quote from 2009 Manual
<R67> All outputs from sensors, custom circuits and additional electronics shall connect to only the
following:
A. Other custom circuits, or
B. PWM Out, I2C, Relay or Digital I/O ports on the Digital Sidecar, or
C. Analog In ports on the Analog Breakout.
D. Ethernet Port 2 on the cRIO Mobile Device Controller (to which the Kit Of Parts-provided
camera, and only that camera, may be connected).
Unread 23-01-2010, 09:08
Well then, three strikes and you're out! Illegal motor, illegal pneumatic part and illegal method of driving it.
Unread 28-01-2010, 16:16
djdaugherty djdaugherty is offline
Mrs. D.
FRC #2053 (TigerTronics)
djdaugherty is on a distinguished road
Is this ilegal because of the modified pwm signal, or is it the regulator itself. <R72> g specifically states that pressure regulators may be used.
<R68> additionally states that outputs from sensors, custom circuits and additional electronics may connect to
B. additional COTS electronics
Also, could you just give it a signal from the cRIO?
Unread 28-01-2010, 17:04
The regulator has a motor inside that does the work=Illegal motor. Not a specified pneumatic part=illegal pneumatic. Not fed through a speed controller or spike=illegal electrical usage.
Unread 29-01-2010, 09:07
Mrs. D.
I submitted a question to the official Q&A asking if electronic regulators are allowed. Do all questions that are asked get answered? If so, what is the general turn around time?
Thanks!
Unread 29-01-2010, 09:33
DJ,
It is my understanding that all questions do get answered although they may be lumped together. As you can imagine many teams have similar questions that can be answered in a single response. As always, simple answers can be given in a short period of time and tougher ones will take longer as discussion among the members is required. I don't think there is any fixed time in which you can expect a response. Please be patient.
Unread 29-01-2010, 10:35
Mrs. D.
Thank you. I've never posted to the Q&A before, so I wasn't sure what the protocol was. I appreciate the information.
Deb
Unread 31-01-2010, 11:20
jspatz1's Avatar
AKA: Jeff
Note that it says outputs FROM sensors, not TO devices. Control outputs to devices other than kit motors, solenoids valves, or legal servos are not permitted. And as already stated, the e-regulator is really a servo, steppermotor, or electromagnet of some form, so it is not a legal actuator. An e-regulator is illegal in multiple ways.
Pressure regulator Perci321 Pneumatics 13 24-01-2009 18:48
Does the Norgren Pressure Regulator show working pressure or stored pressure? Madison Pneumatics 7 14-02-2008 17:40
Nason Pressure Regulator Calvin_1631 Pneumatics 9 09-02-2006 00:40
Nason pressure regulator...HELP!!! Bob Steele General Forum 0 25-02-2004 16:08
pressure regulator blindguyinanorg Pneumatics 12 20-02-2004 08:54
