Go to Post Based on EXTENSIVE analysis of this image, I have concluded that we will have to use wires on our robots. I am certain of it. - theCADguy [more]
Unread 16-01-2010, 09:32
grosh grosh is offline
FRC #2147
grosh is an unknown quantity at this point
Set computer to receive it's IP via DHCP?
On page 45.... in Section 1... of the Control System Manual it says, "set your computer to receive it's IP via DHCP". How do we do this?
Unread 16-01-2010, 09:47
whytheheckme's Avatar
whytheheckme whytheheckme is offline
AKA: Jacob Komar
whytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond repute
Send a message via ICQ to whytheheckme Send a message via AIM to whytheheckme Send a message via MSN to whytheheckme Send a message via Yahoo to whytheheckme
Re: Set computer to receive it's IP via DHCP?
The DHCP settings are reached by going into your Network Connections -> Local Area Network Connection (right click)-> Properties -> TCP/IP
I hope this helps. This is also where you will set the static IP.
Unread 16-01-2010, 09:53
FRC #2147
OK- We have been there and set our static IP to 10.21.47.6 (our team # is 2147). Is their something we have to select to set the DHCP? I don't see anything referring to a DHCP in any of these screens?
Unread 16-01-2010, 10:54
Set it to obtain IP address automatically. DHCP is the protocol by which it does that.
Unread 16-01-2010, 11:43
FRC #2147
Thanks! That did the trick.
Unread 28-01-2010, 12:48
Mohit Mohit is offline
FRC #3053
Mohit is an unknown quantity at this point
I have some trouble with that too..
I set the ip to get automatically and then open internet explorer and type in 192.168.1.250 as described in the manual.
Yet I cannot connect to the bridge...
Here is how the wires run
The cisco modem(wrt610n) is connected to the computer through ethernet cable. Then the ethernet cable from the linksys modem(wga600n) is connected to the cisco modem.
I don't know what the probem is so can anyone help?
Thank you for any kind of help.
Unread 28-01-2010, 23:08
Radical Pi Radical Pi is offline
Putting the Jumper in the Bumper
AKA: Ian Thompson
FRC #0639 (Code Red Robotics)
Radical Pi has a spectacular aura aboutRadical Pi has a spectacular aura aboutRadical Pi has a spectacular aura about
I belive you need to connect to the bridge wirelessly to be able to use it. 2 DHCP servers wired directly together is not the best idea in the world
Unread 29-01-2010, 09:38
greglaston greglaston is offline
FRC #3204
greglaston is an unknown quantity at this point
Try resetting the bridge to its factory settings by pressing the reset button for 20 seconds. I also unplugged and replugged the bridge to be sure it was reset.
Also, the 2 ethernet cables into the bridge have to be plugged into the "1,2,3, or 4" Ethernet jacks, not the jack labeled "Internet".
Unread 29-01-2010, 12:44
FRC #3053
I tried it it but still it does not work..
In the manual is says type 192.2689.1.250 and we tried it but id did not work..
Realizing that that it may be a defaut setting we connected the brigde(wga600) directly to the computer and ran ipconfig on command propt, got the ip and default gateway, ran them on a web browser but it still did not work.. we cannot connect to the bridge...
Any suggestions???
Unread 29-01-2010, 13:27
FRC #3053
Sorry for a double post but the ip was 192.168.1.250..
it was little typing error
Unread 29-01-2010, 13:39
Try connecting your PC directly to the WGA600N via Ethernet cable.
Set a static IP on your PC of 192.168.1.6, netmask 255.0.0.0
Then try browsing to 192.168.1.250
Unread 29-01-2010, 14:11
FRC #3053
We already tried...
Unread 29-01-2010, 14:26
Did you disable your PC wireless if you have it?
Unread 19-05-2010, 13:43
Rangel's Avatar
Rangel Rangel is offline
John Rangel
FRC #0842 (Falcon Robotics)
Rangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond repute
Im having trouble with browsing the bridge. We got into the configuration page and did all the steps like rebooting but now when we try to get to the configuration page again, it says connection was reset. What do we do.
2012 Dean's List Winner
2011-2014 Arizona Regional Winners
2016 Las Vegas Regional Winner
2014-? Mentor
Unread 19-05-2010, 17:21
Did you change the bridge IP address when you rebooted it?
Did you then change your PC's IP address to be compatible with the new bridge IP address before you tried to reconnect?
That's the most common snag.
I presume you are hard-cabled from the PC to the bridge while doing this, or are you going through the router too?
Batch files to switch between DHCP and Static IP DtD Programming 9 28-01-2010 14:27
changing code after it's set to run at startup smcmahon NI LabVIEW 4 11-02-2009 19:36
How many IR Boards did you receive? SpaceOsc General Forum 3 22-02-2008 16:17
pic: It's a bird.. It's a plane.. It's the 573 Mech Warrior bot! Lisa Perez Robot Showcase 3 27-02-2005 15:09
NJ Regional - Anyone like to receive us? Chuck[#1156] Regional Competitions 27 03-03-2004 02:58
