#16
Re: Fasteners extending outside the FRAME PERIMETER
Kevin,
If it helps, bolt heads have always been tested with the box. If in the past you drilled out the back of the bumpers as allowed, the frame perimeter was still set by the maximum dimension of the bolts. |
#17
I was suggesting that a simple workaround if these lower fasteners are not declared legal through the Q&A may be to have identical bolt heads in the level of the BUMPER ZONE so they redefine the FRAME PERIMETER as you mention in your post. This vertical projection of this larger FRAME PERIMETER would enclose the axle bolt heads preventing the <R16> violation. I'm hoping the GDC makes all this moot with an answer to 1771's Q&A, as this workaround is more like a loophole |
#18
The FRAME PERIMETER is a subset of that, the polygon defined by the string stretched around the robot at the BUMPER ZONE level. Even if the FRAME PERIMETER is only 20x30", nothing is supposed to be wider than it, not even a bolt head, whether that is outside 10-16" off the ground. Even if it would fit in the sizing box. Now, are you going to be measuring for that? So the 1/4" extension of a bolt causes the robot to fail inspection? Or are the inspectors and refs only going to be eyeballing it? |
#19
The least nitpicky and anal retentive solution to this would be for the GDC to allow static (non moving) fastener heads to stick out no more than 0.25" from the FRAME PERIMETER, as long as they still fit inside the sizing box. This meets the spirit of the rule of the FRAME PERIMETER (it's not like having a button head stick out an 1/8" from the FRAME PERIMETER, but still within the NORMAL CONFIGURATION, will give that team magical super powers or some unfair advantage) while allowing leeway for teams that can't/won't buy flat head bolts and a countersink tool.
The GDC has been getting better about these kind of situations lately, with relaxed tape rules, relaxed pneumatic rules, etc so I'm hopeful this will be the outcome here. Quote:
#20
As an aside, and as a general rule, we always design out robot to be at least 1 inch smaller than max footprint in all directions, allowing for any covers or fasteners, or stuff that may happen later.
The thing that would make this easiest this year would be to design the "lower" part of your frame to be a little smaller than the "mid" or "upper frame" that your bumpers attach to. |
#21
Thank you Rich. Our design has the 'lower' frame (at wheel level) just a bit smaller than the 'upper' (bumper zone) frame, about 1/2" on all sides. The upper frame is just under 27" wide.
The simple solution is not adding dummy fasteners, but a 1/4 (or 3/8", whatever) strip along the outside of the frame perimeter. Nothing says it can't be birch plywood (lightweight) strips. In theory, the lower frame could be as much as three inches smaller, eh? |
#22
Gary,
I believe, as you suggested, that the FRAME PERIMETER in the strict definition is the outside of the frame including any fasteners in the bumper zone. It is those dimensions that would also define the extent to which fasteners and other parts can extend out from the robot body because that now defines the NORMAL CONFIGURATION. I think it will be fairly easy to tell with the robot in the sizing box with no bumpers. As the rules allow clearance holes and pockets in the backing of the bumper (R07, D), I believe the GDC is allowing the fasteners and therefore the FRAME PERIMETER to merge with the inside of the bumper as they have in the past. Depending on individual design, it may be necessary to have a team rotate their robot to test all sides to insure compliance with these rules as the sizing box really has only two solid sides. |
#23
Everyone keeps focusing on the sizing box. This question has nothing to do with the max legal size for NORMAL VOLUME. Only with frame perimeter. The sketch below is of a 12" square bot, which could never have issues with the sizing box. However, as the rules currently read, is not legal. Since we have not yet recieved an answer, the only alternative is to desigh the bot so that this does not occur. If this is truly illegal, I would expect a great deal of trouble for some teams at inspection this year.
#24
Now that I've thought about it more, I think that there should be some sort of concession made for bolt heads extending outside of the frame perimeter, but within the maximum sizing volume. I know the last two robots we've built on the C-base had bolt heads extending outside of the frame perimeter and I'd assume most teams using it this year would have the same issues... Hmm. |
#25
Martin,
As I look at your drawing, there are no fasteners in the bumper zone and so those dimensions (12 x 12) become the FRAME PEERIMETER. Therefore the fasteners at the bottom of the chassis extend beyond those dimensions. If this robot was placed in the sizing box, the fasteners outside the bumper zone would contact the vertical sides of the box before the frame in the bumper zone and would therefore not meet the definition (as I understand the rules at this date) even though the robot is significantly smaller than the sizing box. |
#26
It's an interesting can of worms, it's good to see this much discussion about it, because this is an issue that many inexperienced teams will probably overlook. |
#27
What about the kit bolts? Seems to me that the 3/8" bolts usually have a head around .290" thick?
We're using 1/2" axle bolts this year ![]() (the heads are welded to the frame, and the threads stick out not quite as far as the FRAME PERIMETER, but still.....) Last edited by MrForbes : 29-01-2010 at 10:09. |
#29
im almost positive that in past years, the robot perimeter has included static boltheads...otherwise there will be A LOT of counter sinking on our hands
#30
In past years these bolt heads were inside the Bumper Zone
| kicker extending outside of robot | caincteam2777 | Technical Discussion | 5 | 17-01-2010 22:42 |
| Frame Perimeter x Bumpers | sloteera | Rules/Strategy | 8 | 14-01-2010 11:18 |
| Frame Perimeter? | jimbot | General Forum | 2 | 10-01-2010 13:48 |
| Holding of Game-Pieces Outside the Robot Perimeter | MikePres | General Forum | 2 | 24-01-2009 07:21 |
| Ramps extending outside of the home zone | Shomron1690 | Rules/Strategy | 31 | 20-03-2007 13:49 |
