Go to Post You lame pig farmer! I'm not talking about a bunch of dudes sitting around eating their packed lunches that Mommy made. - Paul Copioli [more]
Unread 29-01-2010, 10:29
Re: Using non KOP router, possible cause of wireless communication issues?
Originally Posted by saba View Post
Well, the connection to the robot is often lost and then regained, we can't drive it for more than a couple seconds at a time when we get the connection without losing it again, and there is often a delay in the communications.
Hang on a second. When you lose the connection, is it typically right after you start driving? It might be a battery voltage issue. Where do you have your WGA power connected? It might also be interference from motors and/or speed controllers. Where do you have your WGA mounted?
configure wireless router johncap100 FRC Control System 1 21-01-2010 22:40
Wireless Router to Connect with Driver Station Happyisgood FRC Control System 15 04-09-2009 00:02
Use of Wireless Router Andrew Lindsay Rules/Strategy 3 12-01-2009 14:17
Wireless problem - losing communication jalburty FRC Control System 9 09-01-2009 07:35
Wireless Router Issues zim2411 Scouting 17 09-04-2008 22:24
