Go to Post In the end, if our products are crap, then people will not buy them. This is the risk of doing business, and the foundation of capitalism. - Andy Baker [more]
View Poll Results: Which Route Are You Taking?
C++ 53 31.36%
Java 38 22.49%
LabView 78 46.15%
Voters: 169. You may not vote on this poll
Unread 29-01-2010, 10:42
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Calling Out All Programmers
Which route are you guys taking to code the robot? C++, Java or the LabView?
I seem to have to use Java... I wanted to use C++ but my mentor is like "The C++ Libraries Are Too Messy" or something like that... And that the Java code wont be any slower than the C++ because of FPGAs or something
Unread 29-01-2010, 10:49
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
Re: Calling Out All Programmers
LabVIEW. We like the real-time front panel.
Kettering Motorsports
keehun's Avatar
keehun keehun is offline
Team Captain
AKA: Keehun Nam
FRC #2502 (EP Robotics)
keehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond repute
Send a message via AIM to keehun
That's kind of funny actually -- since you can literally take C++ code, change the syntax to Java (like capitalization, accessors, etc) and compile it. Likewise, you can take Java code and change the syntax and compile it with WindRiver. I actually found C++ file a lot more elegant than LabView files we tried last year. The biggest difference is real-time execution (C++ is fast -- but is it "live" like LabView? -- I don't know). LabView by nature is slower, but it is able to process multiple things at once -- a tradeoff?
Anyway, We're using C++. We have a opensource Github, but latest code's not pushed yet. Perhaps I'm wrong about it, but I think your mentor's off the mark when he says "messy libraries". And also, are you the only programmer? How many others are there? What's your guy's consensus on a language preference? A mentor shouldn't force the students in to anything. (Except maybe administrative functions?)
That's just how my team rolls...
Thanks,
Keehun
Team 2502
For by grace you have been saved through faith, and that not of yourselves; it is the gift of God, not of works, lest anyone should boast. -- Ephesians 2:8-9
2010: Quarter Finalist (MN 10,000 Lakes)
2010: Website Award (MN 10,000 Lakes)
2009: Quarter Finalist (MN 10,000 Lakes)
2009: GM Industrial Award (MN 10,000 Lakes)
Unread 29-01-2010, 10:52
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Thanks,
Keehun
Team 2502
Yea I code in Java and C++, I been using C++ longer and I like it way better than Java, well the mentor said I CAN use C++ but he highly recommends Java for the sake of the cleanness of the libraries and easier setup
edit: Im the only guy going for C++ LOL All the other programmers want Java since they don't know C++
Edit of Edit: Amen to your sig
Unread 29-01-2010, 10:53
basicxman basicxman is offline
Emily Horsman
FRC #2200 (MMRambotics)
basicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant future
Send a message via AIM to basicxman Send a message via MSN to basicxman Send a message via Yahoo to basicxman
I'm taking the C++ route for a few reasons
  • Myself and programming partner already knowing C++
  • It's in it's second year with FRC, Java is in it's beta year for FRC
  • More documentation then Java
  • The library is in fact quite straight-forward
C++ has always been my favourite programming language. And I do believe the Java code is going to be slower than C++ code as you're running a virtual runtime on the cRio, this is an extra process whereas WindRiver compiles C++ directly the PowerPC Architecture assembly.
I do not agree with your mentor depicting the C++ libraries (especially the WPI library) as too messy. It is in fact quite easy to pick up an extra class of the library and integrate it in your code. For example I hadn't programmed a Spike relay in C++ before and I ended up accomplishing the feet in five minutes just by taking a quick look at the C++ reference found here, http://www.virtualroadside.com/WPILib/index.html.
LabVIEW is a good choice for a lot of teams, it has more advanced and easy to use debugging tools that supposedly "just work." It has a large community over at the Texas Instruments website with tons of sample code and even video documentation. The problem I have with LabVIEW for one is that it's a graphical language. For some this great, for others (like me) I prefer manipulating a robot or computer with syntactical text. LabVIEW also requires lots of screen real estate which some of the ancient computers at our school don't have, and there's not as many books out there on LabVIEW that I can reference to new programmers.
Just putting in my two cents
Unread 29-01-2010, 11:03
Emily Horsman
I had a programmer from another team mistake my C++ code for Java.
Unread 29-01-2010, 11:05
keehun's Avatar
Team Captain
AKA: Keehun Nam
Ok, well, if all the other guys want Java, then I say just stick with Java. One of coolest things about FIRST is that it teaches you the benefits of working as a team. For my programming team, majority of the guys know Java, but we chose C++ as a preference for two reasons:
  1. We didn't want to try a "new" language for the cRio platform
  2. C++ was proven to work and was fast
  3. We all kinda-sorta knew C++
  4. Being a captain, I pushed for C++ after having a bad experience with LabView last year
  5. Our mentor is like a 30 yr veteran in the field of C++ and Systems Networking
After working with it for a couple weeks, I feel C++ was the right choice, but I know that Java or LabView would've equally been fine. Maybe not LabView, but that's only because trying to wrap all the programmer's mindset around the real-time execution paradigm is difficult. Even the 30-yr C++ veteran mentor (he's also a huge expert in Java) didn't know why LabView behaved the way it did -- that was the real downer last year. Also, we wanted to diff and git with C++.
Unread 29-01-2010, 11:18
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
int Java = 10;
void Print(const char[] Text)
//Not Putting This In...
for(int C = 0; C < Java; C ++)
if(Java < 100 && > 10)
Print("Is this Java Or C Or C++??? Who Knows?");
Unread 29-01-2010, 20:17
Bigcheese Bigcheese is offline
C++0x FTW!
AKA: Michael Spencer
FRC #1771
Bigcheese is a jewel in the roughBigcheese is a jewel in the roughBigcheese is a jewel in the roughBigcheese is a jewel in the rough
We're using C++ again this year for the following reasons.
  1. Most of the student programmers know it (the ones that don't know Java).
  2. I (the programming mentor) know it and work with it professionally.
  3. It offers more control over the execution environment and full access to VxWorks.
Huh? What do you mean by "real-time execution"? You can't get any more real-time than interrupt driven C/C++.
It is not possible to do multiple things at once on the cRIO in any language without using the FPGA. You can get rather close by using multiple tasks or interrupts, but there is only one core which means only one hardware thread running at a time.
BTW, Java and C++ may be similar on a small part of the syntax level (just like every other curly brace language), but they are far apart semantically or when using any of their features.
Unread 29-01-2010, 20:34
DjMaddius's Avatar
DjMaddius DjMaddius is offline
AKA: Matt Smith
FRC #2620 (Southgate Titans)
DjMaddius is an unknown quantity at this point
Our team is going with C++.
Unread 29-01-2010, 21:28
TheDominis TheDominis is offline
FRC #2152
TheDominis has a spectacular aura aboutTheDominis has a spectacular aura about
I use C++ because I don't know how to drag and drop LabView code . Also I dislike Java.
Unread 29-01-2010, 21:34
TPNigl TPNigl is offline
FRC #0069 (Team HYPER)
TPNigl is an unknown quantity at this point
Our team is going with Java because we like the overall structure of the program. We didn't have such a strong foundation in java last year, plus the main programmers this year, myself and my friend, are stronger in Java than C++, so we figured we should try Java, which is working very well for us so far.
2011 Pit Crew:
2011 CT Xerox Creativity Award
HYPER Alumni
Unread 29-01-2010, 22:02
RKElectricalman's Avatar
RKElectricalman RKElectricalman is offline
Meezy the Mentor
AKA: Rameez
FRC #0384 (Sparky 384)
RKElectricalman is just really niceRKElectricalman is just really niceRKElectricalman is just really niceRKElectricalman is just really nice
Send a message via AIM to RKElectricalman
I wanted the team to use C++ last year, but due to the lack of time, experience with C++, and impression that labview's GUI would be much easier, we ended up going with the latter.
It actually took less time to program in C++ then it did in Labview. It took us up until 2 days before the ship date to figure out where all of our issues stemmed from in the GUI. Not to mention it was slow on our set up. For C++ it's been much more smooth of a ride.
On the first day of the season I got all of my programmers together, taught them the basics, and by end of week one they each had programmed a small portion on the code. By end of week two, they had dived right into the use of sensors, and more intricate styles of programming... end of Week three and now they're creating their own classes for certain objectives they've set for their programming. WPILib, is AMAZING!!!! It makes everything so much easier, and with my basic understanding of C and C++ I can explain why things work the way they do, and they can learn more intricate things with delay of coding and confusion.
I. LOVE. C++. <3
-Meezy
ahhh Division Finalists!!
Unread 29-01-2010, 22:17
Radical Pi Radical Pi is offline
Putting the Jumper in the Bumper
AKA: Ian Thompson
FRC #0639 (Code Red Robotics)
Radical Pi has a spectacular aura aboutRadical Pi has a spectacular aura aboutRadical Pi has a spectacular aura about
C++ for me. I tried Java for a bit on the cRIO from the classmate while our new development computer was being set up. I ran into about 10 errors that were really not errors but the dev environment being jumpy. Haven't opened netbeans since
Unread 30-01-2010, 00:29
Brent Strysko Brent Strysko is offline
President
AKA: JCODER
FRC #1672 (Mahwah Robo T-Birds)
Team Role: Webmaster
Brent Strysko is an unknown quantity at this point
Team 1672 will be using C++ as we had hacked up the c++ library last year, and feel that we do not want to have put all that time to waste.
Calling on FIRST to help me out :) Greg Perkins Chit-Chat 7 02-08-2007 02:33
Calling All Homeschoolers Penny Team Organization 1 26-04-2005 10:51
Calling all PHP/ASP programmers! blueWarrior FIRST-related Organizations 15 27-01-2004 13:24
Calling all Lawyers... ...Define "all parts" Joe Johnson General Forum 10 13-03-2002 15:12
Calling all Tigerbolt Chatters - And All Newcomers! Lora Knepper Chit-Chat 9 11-07-2001 18:09
