Go to Post I know my posts are sometimes exhausting but there are PICTURES in this one, if that helps at all. - Jaine Perotti [more]
Unread 29-01-2010, 12:23
joek's Avatar
joek joek is offline
Team Welder and CAD tech
FRC #2052 (KnightKrawler)
joek is an unknown quantity at this point
Re: Where is the design tab located?
i tried it, and it didn't work, it wouldn't go from the output sprocket to the sprocket on the mechanum
2012 Record (13-2-0)
lake superior regional finalists- thank you WAVE (2826) and Blue Twilight (2220)
Unread 03-02-2010, 01:41
inventor_phild inventor_phild is offline
inventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant future
All,
Difficult to tell the exact problem, but I suspect that you need to change the options under Sprocket Geometry Option.
1. In the Roller Chains Generator dialog box, click the down-arrow beside Sprocket. There are 3 options, Component, Existing, Vitrual.
2. If the sprockets already exist (and it sounds like they do) select Existing.
3. Keep in mind that it generates a solid representation of the chain or a sketch. We do not need to see actual chain links in a design, the chain data is more important.
Phil
Unread 03-02-2010, 16:29
Abole Abole is offline
FRC #3284
Abole is an unknown quantity at this point
Sorry, took so long to reply, i found the design tab, just forgot about the assembly part of it from an ipt... thanks though, and it was for making the chains
Unread 03-02-2010, 19:00
joek's Avatar
ok, i used the roller chain generator, and it said this:
"chain drive trajectory is corrupted or data are inconsistent with build in rules. calculation cannot continue"
and
"no sliding sprocket within the chain drive. please set one sprocket as sliding."
Unread 16-02-2010, 17:13
FRC #3284
You might need to put a sprocket, so there is a place that the chain can start from. Thats one thing i noticed but it was easier just putting them straight in on the assembly of the whole robot.
Unread 17-02-2010, 13:44
joek's Avatar
i started a thread about this after my post.
[Official 2008 Game Design] OK, so YOU design the 2009 game... dlavery FRC Game Design 69 23-08-2009 19:54
[Official 2007 Game Design] OK, so YOU design the 2007 game... dlavery FRC Game Design 44 17-12-2006 17:05
So wats ur teams name and were are you located C-MAN Chit-Chat 27 18-10-2004 17:54
TAB command in Pbasic virusmirusne Programming 11 25-01-2003 02:51
