Go to Post A poor robot with good drivers playing on good strategy will whomp a good robot with poor drivers running on poor strategy any day. - henryBsick [more]
Unread 22-01-2010, 17:31
Raj1977's Avatar
Raj1977 Raj1977 is offline
Retired Battery Maven
FRC #1676 (Pascack Pi-Oneers)
Team Role: Electrical
Raj1977 is an unknown quantity at this point
Exclamation Wiring Switches to the PSoC board
Hey, does anyone know how to wire switches to the PSoC board included in the kit of parts... we want to use it for autonomous. There don't seem to be any resources for it? Is it similar to the big blue box that there was last year?
Unread 22-01-2010, 23:31
Re: Wiring Switches to the PSoC board
  • Switches just need two wires: signal (white) to P4_4 & ground (black) to ground. The power wire (red) is unused.
  • Pots use all three wires: signal, ground, & power (note: full range of pot will be read by your code as 0 to 3.3)
Pinout
Unread 23-01-2010, 21:06
Jim.D Jim.D is offline
FTC #1983
Jim.D is an unknown quantity at this point
I don't think your robot will listen to the board in autonomus mode unless its on the robot.
Yes the PSoC is much like the blue box from last year. You have to load a hex file onto it. The file comes in the control station update. You can plug PWM pins directly to the I.O. pins on the board or use a carrier board. andymark has one for 22.00. If you plan to hook a laptop other than the control station to the PSoC you have to use the breadboard from the kit.
Unread 23-01-2010, 22:02
It will listen to it in disabled mode, so you can read the setting and then use it in autonomous mode. It may even latch the values, so it can be read in autonomous mode (but not changed).
Unread 23-01-2010, 22:32
ChazA's Avatar
ChazA ChazA is offline
FRC #0116 (Epsilon Delta)
ChazA is an unknown quantity at this point
Be careful. I believe any board other than the KOP breadboard is prohibited by the rules (including the one offered by AndyMark), as clarified by this Q&A Thread:
http://forums.usfirst.org/showthread.php?t=13781
Unread 23-01-2010, 22:51
FTC #1983
My read on the rules for the I.O card R60 and R82 only require the stock binary file if the board is used for the driver station and that the bread board be used if you are connecting a 2nd laptop or such device to the driver station.
I saw on here somewhere that there was also a ruling that the carrier board could be used but I'm not shure if that was for switches or periferal connection.
Unread 24-01-2010, 06:24
Happy Birthday! mcf747 mcf747 is offline
AKA: Matthew Forman
FRC #0190 (Team 190)
mcf747 has much to be proud ofmcf747 has much to be proud ofmcf747 has much to be proud ofmcf747 has much to be proud ofmcf747 has much to be proud ofmcf747 has much to be proud ofmcf747 has much to be proud ofmcf747 has much to be proud of
True.....at one point.
I believe it has been overturned by team update 4.
Matthew
Unread 24-01-2010, 08:42
That is true, the words "the breadboard" in R82 have been struckout. It now reads...
TU#4
<R82> Teams are permitted to connect a portable computing device (Laptop computer, PDAs, etc.) to the DRIVER STATION for the purpose of displaying feedback from the ROBOT while participating in competition MATCHES. Portable computing devices may only connect to the DRIVER STATION through one of the USB ports or through the First Touch I/O module (or a carrier board for the First Touch I/O module) – they shall not connect to the DRIVER STATION through any other port.
Unread 29-01-2010, 09:52
Phalanx's Avatar
Phalanx Phalanx is offline
Formerly Team 1089 (Mercury)
AKA: Michael Reffler
FRC #5431 (Titan Robotics)
Phalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond repute
Since they've now allowed use of other boards, like the on from Cross the Road Electronics...
We'd like to use our PSOC-3 and create an LED feedback system for our Robot Driver Controls. Since we can have up to 8 eight digital output signals we thought this would be useful. (8 LED's at 20mA = 160Ma max)
In the past, on the old IFI system we could only draw about 100mA. However, I am unable to locate any information on the PSOC-3 datasheet telling me how much I can source on those digital outputs.
I know the PSOC-3 being power by USB is only about 500mA on the USB so it is probably much less than that.
Does anyone know or can point me at how much I can draw/source?
Thanks
Don't just ask the experts, become one!
Leadership is not about ability. It's about responsibility!
Diagonally Parked in a Parallel Universe. It's okay we do Quantum Physics
Unread 29-01-2010, 10:06
Michael,
I could find no reference in the literature either. This may be a questions for Customer Support.
Unread 29-01-2010, 11:56
FTC #1983
I could not find printed details but in the Cypress Creator program when you set up the pins the setup options are something like 1) sink 4 ma or source 8 ma 2) High current mode 25 ma. I don't know how many pins you coud drive simultaniously in high current mode. There is a Frist forum on the Cypress site, they could probably get you a better answer.
Jim
Team 1983
Unread 29-01-2010, 12:35
There are some details FIRST has now put together and published on the Control System page:
Cypress First Touch I/O Module - Pinout
Unread 29-01-2010, 12:38
Mike,
Firefox can't find the url
Unread 07-02-2010, 23:24
Commando3157 Commando3157 is offline
FRC #3157 (Iron Lancers)
Commando3157 is an unknown quantity at this point
I am having trouble finding info on the wiring and programming of this also. If anyone finds anything, post it please because that PDF doesn't tell me what I need to know!
Wiring The IR Board joesmomh00haha Sensors 2 12-02-2008 15:30
Wiring the IR sensor board govvijay Programming 9 05-02-2008 19:41
Need tips on wiring the IR board Bryan Herbst Control System 4 12-01-2008 18:34
Making switches that plug into the oi board cdennisxlx2 Control System 2 12-02-2006 20:59
Wiring Switches To the Operator Intrerface archiver 2000 2 23-06-2002 23:02
