Go to Post For those of you who don't want to read a block of text: Respect the Tools. - Andrew Schreiber [more]
Unread 28-01-2010, 20:00
amitaggarwal11 amitaggarwal11 is offline
FRC #1351
amitaggarwal11 is an unknown quantity at this point
Prototype of Goal
I am trying to find the inner dimensions of the front of Goal, for prototyping purposes. The dimensions I have are somewhat estimated:
width = a little less than 4 feet
ground to bottom of goal = 5 and 1/8 inch
bottom of goal to top = between 28 7/8 in and 29 3/8 in
I got all of these through using the field documents GE-10034 (rear ramp), GE-10035 (large side), GE-10036 (small side), and GE-10061 (goal, assembly). Please let me know if you find any more definitive inner dimensions.
Unread 29-01-2010, 13:07
DuaneB's Avatar
DuaneB DuaneB is offline
FRC #1731
DuaneB is an unknown quantity at this point
Re: Prototype of Goal
From the GE-10061 (Goal, Assembly) drawing, it looks like item 6 (GE-10031 - Goal Frame, Left) spans the width between the uprights at each side of the goal. GE-10031-01 (Square Tube) is the rail member and its dimension is shown as 48.75 inches.
I'm not sure what you mean by the bottom of the goal, but GE-10033 (Goal Front Ramp Assembly) shows 7 1/4" for GE-10033-02, Front Ramp Inner Support, plus 1/2" thickness of GE-10033-01 (Front Ramp Platform) for a front ramp height of about 7 3/4".
As for goal height, FE-00001 (Drivers Station Support) shows the connector shaft centered 35 7/8" off the floor. Subtract half the height of the 1 3/4" square tube (7/8") and the front ramp height (7 3/4"), and you get 27 1/4".
#1860 kicker prototype sloteera General Forum 12 04-02-2010 14:27
Team 241's Turret Prototype ontop of the Harvester Prototype Dantvman27 Robot Showcase 39 08-02-2009 22:53
Prototype Drive ZeroValue Technical Discussion 16 06-11-2008 18:31
Warning: No Function Prototype CronosPrime1 Programming 7 18-02-2006 09:48
Roller Prototype sdexp Robot Showcase 0 04-02-2006 22:41
