Go to Post ...several people have told my that my brain has been oxygen-starved since at least 1975. - dlavery [more]
Unread 29-01-2010, 13:31
Dad1279 Dad1279 is offline
FRC #1279 (Cold Fusion)
Re: #35 Chain tool
No tool necessary. I like to just grind the tips of the pins off, then they can be pulled out by hand, or with a small screwdriver or small punch.
Dremel or small bench grinder works well.
Unread 29-01-2010, 13:35
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
Re: #35 Chain tool
It may not be absolutely NECESSARY, but it REALLY NICE to have.
That McMastger Chain Breaker Tool is the best $30 you'll spend.
Joe J.
Team #88, TJ2
Unread 29-01-2010, 14:02
Steve_Alaniz Steve_Alaniz is offline
FRC #2848 (All Sparks)
Steve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond repute
Re: #35 Chain tool
Since this thread has gotten out of New York let me put my two cents in. We use a chain pin removal / installation tool. It allows us to extract a pin and then re-insert it. There are two advantages to this. First, if someone breaks the chain the wrong length, no problem, we just reinsert the pin and restore the chain to its original length. Second, we don't need master links. By being creative in our mounting we can tension the chain which is a continuous loop so we don't have to worry about losing a master link during game play.
In addition to all that, once you get the hang of it, I think it's a lot easier to use than the traditional chain breakers .
http://www.kartpartsstore.net/servle...ers/Categories
Steve
Team 2848
Unread 29-01-2010, 19:26
craigboez's Avatar
craigboez craigboez is offline
Mechanical Engineer
AKA: Craig Boezwinkle
FRC #2811 (StormBots)
craigboez is just really nicecraigboez is just really nicecraigboez is just really nicecraigboez is just really nicecraigboez is just really nice
Re: #35 Chain tool
Steve
Team 2848
After buying a Dark Soul chain tool for #25 chain (which is awesome) I was looking for something similar to use on #35 chain. This is exactly it.
The chain removers/installers beat the heck out of a "chain breaker" tool + master link setup.
Unread 29-01-2010, 22:00
AKA: Dr. Joe
FRC #0088 (TJ2)
Re: #35 Chain tool
Depends on what you need. Sometimes it is a pain in the rear to have to put the chain on as a loop and it is easier to thread a single strand through the assembly and then install the master link.
Joe J.
Team #88, TJ2
Unread 30-01-2010, 00:27
joek's Avatar
joek joek is offline
Team Welder and CAD tech
FRC #2052 (KnightKrawler)
joek is an unknown quantity at this point
Re: #35 Chain tool
EVERY link is a master link if you have a pin tool
2012 Record (13-2-0)
lake superior regional finalists- thank you WAVE (2826) and Blue Twilight (2220)
Unread 30-01-2010, 02:35
AKA: Dr. Joe
FRC #0088 (TJ2)
Re: #35 Chain tool
Yes and no. If you can get to the chain with the tool in position and you can get enough slack to make it work, etc.
Plus there is a limit to the number of ins/outs you can put per pin.
There are pluses, yes. There are also some negatives.
Weight the options and make your choices. For my part, I have never had a problem with well designed chain routings and standard master links.
Cheers,
Joe J.
Team #88, TJ2
Unread 30-01-2010, 09:09
Tony.Wu Tony.Wu is offline
Carnassial
AKA: Dave The Mechanic
Team Role: Animator
Tony.Wu is an unknown quantity at this point
Send a message via MSN to Tony.Wu
Re: #35 Chain tool
They should sell it in a bike shop.
Unread 01-02-2010, 16:38
craigboez's Avatar
Mechanical Engineer
Re: #35 Chain tool
Just an FYI, I ordered one of these on the 29th from the Kart Parts Store website and it just arrived. Three days from order placement to product receipt, and that was free non-expedited shipping. The tool looks like a winner and the merchant gets 5 stars too.
chain tool alysume Technical Discussion 12 05-04-2007 13:17
Converion Tool? atifce Programming 1 05-04-2007 03:19
Chain Drive chain Damelvin 3D Animation and Competition 2 15-02-2005 00:19
Tool for one, Tool for all Gadget470 Team Organization 6 01-10-2003 02:41
Chain and chain breaker source? kmcclary Off-Season Events 4 22-10-2001 22:51
