Go to Post Slight physical blocks will never stop a good programmer, we can just program around it. - AIBob [more]
Unread 29-01-2010, 01:02
oddjob oddjob is offline
oddjob is a splendid one to beholdoddjob is a splendid one to beholdoddjob is a splendid one to beholdoddjob is a splendid one to beholdoddjob is a splendid one to beholdoddjob is a splendid one to beholdoddjob is a splendid one to behold
yet another No Camera Images on Dashboard thread
We have configured the user accounts and IP of the camera. The dashboard is the right one with a compass in the lower right, no thanks to the installer that doesn't work. The Windriver and dashboard PC has 10.xx.yy.6 IP and the driver station is running on the classmate at 10.xx.yy.5, set to remote dashboard at 10.xx.yy.6. We can build CameraToDashboardExample and run it. In the console we have confirmation that the ImageServer is starting (or whatever it is called, I won't be using the cRIO again until Saturday). Tried toggling the green button below the image window in the dashboard. Not a single frame comes through. What to try next? I can post the exact console messages on Saturday.
A separate issue: created a new program that won't compile due to inclusion of AxisCamera.
class TeamRobot : public IterativeRobot
  DriverStation *ds;
  RobotDrive *drive;
  Joystick *TMjoystick;
  AxisCamera *camera;  // this is line 26
public:
  TeamRobot(void)
    ds =                  DriverStation::GetInstance();
    drive =           new RobotDrive(1, 3, 2, 4);
    TMjoystick =      new Joystick(1);                  // create the joystick
    camera =              AxisCamera::getInstance();    // create the camera
    camera->writeResolution(k320x240);
    camera->writeBrightness(0);
The compile error message is
C:/windriver/workspace/TeamRobot/TeamRobot.cpp:26: error: ISO C++ forbids declaration of `AxisCamera' with no type
C:/windriver/workspace/TeamRobot/TeamRobot.cpp:26: error: expected `;' before '*' token
If I remove all camera lines of code, it compiles fine. Now what?
Unread 29-01-2010, 01:09
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Re: yet another No Camera Images on Dashboard thread
Ok - I'm probably going to put my foot in my mouth since I haven't played with the C++ implementation or the Java either, but with labview you actually need to deploy the default framework (which includes the camera code) to the Crio before seeing any pictures on the dashboard.
Have you attempted to deploy the default program supplied with no modifications?
Unread 29-01-2010, 01:17
Yes.
Except there may have been some include file edits needed to get the example to compile. One of the camera examples needed some edits. We can't get any images on the dashboard running CameraToDashboardExample. The cRIO has been imaged to C++ v19. We can run a mecanum drive program that doesn't include any camera code.
Unread 29-01-2010, 10:29
I tried adding AxisCamera to a new "BuiltinDefaultCode" project and it compiles with no errors, so there is something busted in our robot project. We'll fix it by copying our robot code into the new project and move on. It would be nice to know what's broken, but the clock is running.
Unread 29-01-2010, 12:56
jc4p jc4p is offline
AKA: Kasra Rahjerdi
FRC #2412 (Robototes)
jc4p is an unknown quantity at this point
Does the green LED on the secondary ethernet port on the cRIO turn on and stay on when you turn the robot on?
Unread 29-01-2010, 13:42
sircedric4's Avatar
sircedric4 sircedric4 is offline
AKA: Darren
no team (The SS Prometheus)
sircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond repute
We have had that exact same problem! Our installer didn't work either and we had to manually install everything and we also had troubles with the AxisCamera compiling. We got that same error code.
We did what jhersh recommended in another thread, and removed the files from the demo folder. (The thread was: http://www.chiefdelphi.com/forums/sh...t=80970&page=2) We did as they suggested and still were having the same problem. We finally started a new example based on the new 2010ImageDemo and just blew away the *.cpp files and copied our *.cpp files into the project. That allowed the program to compile with the AxisCamera code but we still aren't getting images.
To top it off, whenever we have the AxisCamera active, the robot acts extremely flaky. We don't get images, and in addition we are getting intermittent communications and both the communications and robot code lights on the dashboard flash red and green. If we move the robot, it stops and goes and stops and goes. This only happens if we call the AxisCamera code.
I've had nothing but trouble with the code since we've started. I believe this weekend I am going to change development computers completely or blow away everything I have from all years of robotics. I think there's just too much to fight if your update installer doesn't work properly and if you have Windriver from last year. (I moved our last year Windriver to another directory and have this years in the default directory, but it doesn't seem to help)
I think it is complete garbage that I have to have a brand new computer each year that's never seen Windriver, but its the only think I can think of to stop having everything we code a battle.
I hope someone helps you with your problem because it will solve ours as well, so I'll be watching this thread.
Unread 29-01-2010, 16:28
Today I installed all the tools on a new PC, plus the patches/updates. Loaded the example code BuiltinDefaultCode and it compiles. Tried CameraToDashboardExample and that compiles.
Then add "AxisCamera *camera;" to BuiltinDefaultCode.cpp and it doesn't compile, same error as before.
Anybody got some magic dust to sprinkle on my PC? Just getting it to compile with a camera object is turning into an epic, and then more than likely, I still won't get images to the dashboard. Much of the delivered code is of a high standard and problem free, but this C++ camera stuff is not ready for prime time.
Unread 29-01-2010, 17:27
Rolland0 Rolland0 is offline
FRC #1684
Rolland0 is an unknown quantity at this point
Regarding the separate issue in the original post, are you including "Vision/AxisCamera2010.h" and/or "WPILib.h"? Regarding the camera, have you run the axis camera setup tool? Our camera didn't work until we did that (but I don't know if it was relevant).
Unread 29-01-2010, 18:36
gvarndell's Avatar
gvarndell gvarndell is offline
Software Engineer
AKA: Addi's and Georgie's Dad
FRC #1629 (GaCo)
Team Role: Parent
gvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond repute
Can you show exactly what you added to BuiltinDefaultCode.cpp and some surrounding context?
I'll take a crack at figuring it out.
Robots never, ever, ever, ever break -- The Robot Repairman (Backyardigans)
Unread 29-01-2010, 18:44
gvarndell's Avatar
Software Engineer
FRC #1629 (GaCo)
Team Role: Parent
By chance, have you, as I did originally, skipped installing the LabView DVD -- thinking it wasn't needed if you were just going to use C++?
Earlier this week, I went back and installed the LabView software (painful exercise that was) and it has helped enormously.
One would not intuitively assume the need to do this.
But it seems to be requisite to success with Wind River C++ development.
Unread 29-01-2010, 20:38
Some progress.
I did two things to the code and environment. Go here and do the steps in post #6:
Then add this to the .cpp file:
#include "Vision\AxisCamera2010.h"
Now I can add this to the code and it compiles:
AxisCamera *m_camera;
Tomorrow I'll attack the problem of no images going to the dashboard.
Unread 29-01-2010, 20:53
gvarndell's Avatar
Software Engineer
FRC #1629 (GaCo)
Team Role: Parent
Some progress.
AxisCamera.h is only already included in a handful .cpp files (BuiltinDefaultCode.cpp is not one of them) and not in any other .h files -- not even WPILib.h.
So, yes, you needed to explicitly add the '#include'.
I think somebody pointed that out to you in another post.
Slow Dashboard Images SOLUTION Radical Pi Control System 17 22-02-2010 12:35
Yet Another Axis Camera Live Feed Issue z2daj FRC Control System 2 24-01-2010 13:47
Yet another Camera thread... Pancake C/C++ 2 26-01-2009 11:42
Yet another bumper thread Vikesrock Technical Discussion 26 19-01-2009 17:04
Yet another dashboard program Neal Probert Programming 3 12-05-2002 10:43
