Re: moter tooth size
As long as you can buy the 19 tooth (or GDC says it came in the KOP this year) then you should be able to use it. Just beware the variety |
| Gear Tooth Code | magical hands | Programming | 1 | 19-02-2007 00:05 |
| Gear Tooth Sensor | nukem | Programming | 9 | 04-02-2006 20:21 |
| Gear Tooth Sensor | AMIRAM | Electrical | 2 | 22-01-2006 04:09 |
| 45 tooth sprockets | maxgebhardt | General Forum | 1 | 26-01-2004 22:45 |
| Trouble with drill moter assembly? | trollin1st | Motors | 3 | 19-01-2003 15:29 |
