Go to Post If you want to know how to build a more competitive robot, ask. GP demands we tell you, help you, guide you, teach you. - Al Skierkiewicz [more]
Unread 29-01-2010, 14:04
Hadi379's Avatar
Hadi379 Hadi379 is offline
FRC #0379
Hadi379 is a splendid one to beholdHadi379 is a splendid one to beholdHadi379 is a splendid one to beholdHadi379 is a splendid one to beholdHadi379 is a splendid one to beholdHadi379 is a splendid one to beholdHadi379 is a splendid one to behold
Re: The 2nd Joystick must DIE
Can someone look at my telop code and let me know if this is correct. I thought I was on the right track, but from other posts on here, I decided to go another route. The image of the telop.vi is attached. Sorry for the poor resolution, but i had to make the file size small enough. Thanks....
Unread 31-01-2010, 02:27
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
It looks reasonable, but there is an easier way to convert from cartesian to polar (the magnitude and direction). In the palette under Programming >> Numeric >> Complex choose "Re/Im to Polar". This VI does all that math internally. The output is in radians, so you still need the conversion to degrees.
In the next update there will also be a VI that takes cartesian inputs so you can wire your joystick up directly.
As for the poor resolution, you should use jpg or png, not bmp. bmp is basically just a raw image with no compression.
Unread 31-01-2010, 09:50
The help implies that some of the inputs should be in degrees. However, when I dug in, it looks like it limits the values to -1 to 1, which implies they should not be degrees, but joystick values. Am I reading that right?
Also, wouldn't putting the gyro in as an input cause positive feedback? Shouldn't that also be a joystick value?
Unread 31-01-2010, 16:16
Originally Posted by Joe Ross View Post
The help implies that some of the inputs should be in degrees. However, when I dug in, it looks like it limits the values to -1 to 1, which implies they should not be degrees, but joystick values. Am I reading that right??
I assume you are talking about digging into the HolonomicDrive VI. It takes 3 inputs... Magnitude (which is from 0.0 - 1.0), Direction (which is in degrees) and Rotation (which is -1.0 to 1.0, but has errant documentation claiming it is in degrees/sec).
Who's putting the Gyro in? I'm guessing you mean into the Direction input. The Gyro only comes into play if you want field oriented control, in which case you would subtract the gyro angle from the desired direction coming from the cartesian to polar conversion.
-Joe
Unread 31-01-2010, 16:23
-Joe
Nevermind, I didn't follow the wires correctly.
pic: In the pit everyone must follow the rules Rich Wong Extra Discussion 3 02-07-2009 15:57
The 2nd and 3rd Clue???? nevereverregret General Forum 4 19-01-2009 20:22
Why MUST the 7.2v battery be attached to operate servos on the RC? Mike Rush Control System 17 06-02-2004 18:57
... And the Boards Die AJ Quick Chit-Chat 19 14-04-2003 13:36
I must be the postman... archiver 2001 4 23-06-2002 22:22
