Go to Post When I'm asked the question, "What is the most important computer language to learn to prepare me for a programming career?"; my answer is, "Your second one." - Greg McKaskle [more]
Unread 29-01-2010, 14:23
falconmaster's Avatar
falconmaster falconmaster is offline
AKA: Ledge
FRC #0842 (Falcon Robotics)
falconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond repute
Send a message via MSN to falconmaster
120 psi pressure reliefg valve
We just received MAC Solenoids from Heitek and they are rated for 120 psi the update from Update 5 says we need to have a second pressure relief valve if you are using solenoids that are rated less than 125psi. Does anyone know where to get a 120 psi pressure relief valve?
Faridodin "Fredi" Lajvardi KD7WKD
Unread 29-01-2010, 14:42
ebarker's Avatar
ebarker ebarker is offline
AKA: Ed Barker
FRC #1311 (Kell Robotics)
ebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond repute
Re: 120 psi pressure reliefg valve
Go look at this thread here
Just get one of these and dial it down to 75 or so and put it on the same bus as the MAC valves and you will be good to go.
EDIT: I'd order the E291 valve, it is rated 0 to 125 psi and has a 1/8 NPT fitting.
Ed
Ed Barker
Unread 29-01-2010, 14:51
Peter Matteson's Avatar
Ambitious but rubbish!
FRC #0177 (Bobcat Robotics)
Here is a p/n for Grainger that you should be able to get easily.
http://www.grainger.com/Grainger/items/6D915?Pid=search
Edit: Here in the p/n in case the link doesn't work- 6D915
Thank-you 294 & 67
www.bobcatrobotics.org
Unread 31-01-2010, 00:00
Ed Law's Avatar
Ed Law Ed Law is offline
no team (formerly with 2834)
Ed Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond repute
I am very confused. First, update 5 says that if we use a solenoid valve rated at less than 125 psi, then we need to have a pressure relief valve in the same zone as the solenoid valve set at its rated maximum.
We are using SMC SY3000 series which is rated at roughly 101 psi. How can the pressure reach over 100 psi when it is in the 60 psi zone regulated by the primary regulator?
The second thing that confuses me is that I just read that we are not allowed to adjust the pressure relief valve. Does that mean we can not buy a pressure relief valve and adjust it to 100 psi? Are we suppose to buy one that is set to 100 psi and not adjustable?
Please don't call me Mr. Ed, I am not a talking horse.
Unread 31-01-2010, 00:58
If a pneumatic cylinder is moved against the air pressure by a strong enough force, it will overpressurize the pneumatic circuit to which is connected. That's why you need a relief valve on that circuit.
I believe a relieving regulator will act as the required relief valve.
You're not allowed to adjust "the" 120 PSI pressure relief valve mounted directly to the compressor. I don't think the rule applies to any other relief valves.
Unread 31-01-2010, 01:06
Ed Law's Avatar
Thank you, I understand now. I will buy a relief valve, set it at 100psi and put it in the 60psi zone. Can I put it anywhere in the 60 psi zone or does it have to be between the cylinder and the solenoid valve?
Adjustable pressure relief valve? ayeckley Pneumatics 18 29-01-2010 14:46
120 psi Main Relief Valve not functioning Clifford Pneumatics 10 11-02-2008 22:29
120 psi penguain Pneumatics 12 11-02-2008 20:41
sighhh can somebody clarify the 120 60 psi CollmandosGrl Pneumatics 3 10-02-2008 18:34
Calibration of pressure relief valve d235j Pneumatics 3 16-01-2008 14:12
