Go to Post Never underestimate the power of curious and impatient FIRSTers ;) - kpugh [more]
Unread 29-01-2010, 14:02
mama_tree's Avatar
mama_tree mama_tree is offline
FRC #3168 (WARRIORS)
mama_tree has a spectacular aura aboutmama_tree has a spectacular aura aboutmama_tree has a spectacular aura about
Jaguars not working
Our team is working on connecting the jaguars for testing purposes. There is continuity from the power distribution panel to the jaguar but when they turn the power on the light does not turn on. How can we check this?
Unread 29-01-2010, 14:41
Re: Jaguars not working
Which connections on the Power Distribution board are going to which screws on the Jaguar? What size circuit breaker have you installed? When you apply power, can you measure voltage across the PDB terminals, and across the Jaguar power input?
If you're lucky, you have a faulty or missing circuit breaker. If you're unlucky, your Jaguar is broken. If you're very unlucky, you've connected power to it incorrectly and you have destroyed it.
Unread 29-01-2010, 14:42
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
Checking the continuity is only part of the testing procedure.
First off, to prevent any more damage, make sure everything is wired correctly. Make sure the polarity to the Jaguar's is correct.
The Jaguar's suffer from a somewhat fatal design flaw. There is no information printed on the Jaguar itself to indicate battery input, motor output, or even the polarity for them.
Here's a picture from the Jaguar manual to show how to wire it.
Name:	Jaguar Wiring.PNG
If you have verified that is correct, then power on the system and check the voltage at the points shown in this picture.
NOTE: Wiring in the sketch is just for demonstration. Don't use it to rewire your robot accordingly.
If no voltage is at the Power Distribution board, make sure you have the circuit breaker in the right spot, and if it is, try to move it to a different section.
My best bet is that the Jaguar's are wired incorrectly. In that case, they are probably toast.
Taking a break from mentoring for a few years. (Is that allowed?!?)
Controls Mentor
@rnazaretian
Previous teams:
Team Fusion, FRC 364
Garnet Squadron, FRC 4901
Unread 29-01-2010, 14:52
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
This is not correct. The Jaguars have raised lettering next to each of the terminals indicating V+, V-, M+, and M-.
They are faintly visible in this picture:
http://www.chiefdelphi.com/media/img...82b43f8c_l.jpg
Unread 29-01-2010, 15:19
RyanN's Avatar
RyanN
That's news to me. Was it always there, or added this year? Their website's flyer doesn't have the labeling there. I also thought that I remember not seeing any labeling last year.
Controls Mentor
@rnazaretian
Previous teams:
Unread 29-01-2010, 15:22
kevin.li.rit's Avatar
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
I believe vikesrock is correct. The lettering was there last year too.
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
Unread 29-01-2010, 15:48
Bryan Herbst's Avatar
Bryan Herbst Bryan Herbst is offline
AKA: Bryan
FRC #2052 (KnightKrawler)
Bryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond repute
Confirming this. They have always had all jaguars, victors, and spikes labeled with the correct terminals.
Team 2052- KnightKrawler
Mentor and volunteer
Unread 29-01-2010, 17:04
mama_tree's Avatar
Thankfully, they figured it out!!
Thanks
Unread 01-02-2010, 07:54
Thanks
Inquiring minds want to know...It might help others with the same problem.
Black jaguars: not working ellisk C/C++ 55 02-02-2010 11:14
Jaguars arent working yoavh360 Electrical 6 19-01-2010 17:20
Victors and Jaguars not Receiving Signal? excel2474 Electrical 1 12-02-2009 16:41
jaguars suddenly not working Mr. E Technical Discussion 1 07-02-2009 21:09
Jaguars working with 2.4 Ghz R/C NOV8R Technical Discussion 0 09-01-2009 16:15
