Go to Post If this truly bothers you, you should do something CONSTRUCTIVE about it instead of whining about it - Jaine Perotti [more]
Unread 01-29-2010, 02:26 AM
biojae's Avatar
biojae biojae is offline
Likes Omni drives :)
AKA: Justin Stocking
FTC #5011 (BOT SQUAD) && FTC#72(Garage bots)&& FRC#0399 (Eagle Robotics)
biojae is a jewel in the roughbiojae is a jewel in the roughbiojae is a jewel in the rough
Java Image Libraries
In C++, there is a file named nivision.h
It contains all of the vision functions that the cRio can do.
Where in java can this be found / used?
Looking for functions like morphology, Advanced Morphology: Convex Hull, and Advanced Morphology: Remove Objects
FTC Team 72 - No site
FRC Team 399 - http://www.team399.org
2010 Rockwell Collins Innovation in Control Award - (Use of the CAN bus, among other reasons) Phoenix, Arizona!
Unread 01-29-2010, 03:47 PM
SavtaKenneth SavtaKenneth is offline
AKA: Yotam Kenneth
FRC #2212
SavtaKenneth will become famous soon enough
Re: Java Image Libraries
There is edu.wpi.first.wpilibj.camera which gives access to the camera. The image processing is found in edu.wpi.first.wpilibj.image. The classes for processing are spread throughout the .image libraries. I know finding ellipses is under MonoImage. For the rest you have to search throughout the files :\
We still didn't get around to programming the vision yet so I can't help you any further. Good luck (:
~Kenneth
Team #2212 The Spikes
Java: Image Recognition Delian Java 1 01-12-2010 10:11 AM
**FIRST EMAIL**/Java and Orbit Balls *****JAVA DISCUSSION*** Pjohn1959 Programming 37 08-31-2009 03:55 PM
How complete are the C++ libraries compared to the LV libraries? tdlrali FRC Control System 3 12-12-2008 07:21 PM
MPLab libraries winners Programming 2 01-29-2006 04:35 AM
