Go to Post My goal as a mentor is to make myself irrelevant. Is that possible? Probably not. But this is one place I am willing to aim stupidly high. - Ian Curtis [more]
Unread 29-01-2010, 12:53
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
Controlling balls above the bumper
Did anybody else catch this fascinating Q&A?
http://forums.usfirst.org/showthread.php?t=14216
By extension of this ruling, you can control ball direction with active mechanisms above the bumper (relative to world coordinates) if your robot is upside down (relative to normal configuration). This opens up some interesting strategies for controlling the ball returns and executing collaborative plays within an alliance. Team 67 had great success with an orientation-changing robot in 2005, as did team 16 in 2008. Now that the door is open, will we see something similar this year?
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 29-01-2010, 13:00
Matt C's Avatar
Matt C Matt C is offline
FRC #1468 (J-Birds)
Matt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond repute
Send a message via AIM to Matt C
Re: Controlling balls above the bumper
Thus, a device that is "below" the BUMPERS when the ROBOT is inverted would be considered "above" the BUMPERS in the coordinate frame of the ROBOT. If such a device were used to control the BALL, then it would be a violation of Rule <G45>.
Am I reading this differently? It doesn't appear to say what you think.
Unread 29-01-2010, 13:03
jgannon's Avatar
I ᐸ3 Robots
AKA: Joey Gannon
Here's the logical inverse of the snippet you posted:
Thus, a device that is "above" the BUMPERS when the ROBOT is inverted would be considered "below" the BUMPERS in the coordinate frame of the ROBOT. If such a device were used to control the BALL, then it would not be a violation of Rule <G45>.
_
Unread 29-01-2010, 13:16
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
You would still have to avoid CARRYING the ball, but I agree with your interpretation based on the GDCs bizarre response.
Unread 29-01-2010, 14:22
Matt C's Avatar
FRC #1468 (J-Birds)
I was interpreting it as the "coordinate frame" flips. That a device "below" (meaning above on a now inverted robot), would be considered as "above" the bumpers and thus not be legal to use to manipulate balls.
Why the heck are they using "" to explain anything I have no idea.
I took the line:
However, it must be noted that the ROBOT rules are defined in reference to the coordinate frame of the ROBOT when it is standing normally on a flat floor.
to mean that if it's standing normally on a flat floor, that is it's defined coordinate frame. So that when the robot flips, so does the coordinate frame assuming that the robot is now standing normally on a flat floor.
Maybe I'm reading too much into it and the refs have to keep a close eye and keep count of how many times a robot has flipped to determine what the "top" and "bottom" of the robot is.
Unread 29-01-2010, 14:36
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
The Q&A post you quoted in your first post seems to imply that the coordinate frame does not flip.
The quoted text suggests that a device that is physically below the bumpers while the robot is inverted would still be considered above the bumpers in the coordinate frame of the robot and thus would incur a penalty under <G45> if used to control the balls direction.
Unread 29-01-2010, 16:05
Locke64 Locke64 is offline
FRC #0063
Locke64 is an unknown quantity at this point
...and a device that is physically above the bumpers while the robot is inverted would still be considered below the bumpers in the coordinate frame of the robot. They're saying down is up and up is down, thus the coordinate plane of the robot has flipped in relation to the field.
So if you're flipped, you can't control balls from under the bumper (because it would be "above" relative to the robot), but (logically) can control them above the bumpers (as long as it doesn't satisfy the definition of POSSESSION).
A very interesting response indeed. Teams building flippable robots may want to consider adapting their mechanism so it can still work while flipped, without POSSESSING the balls. However, they should avoid building a mechanism on both the top and bottom.
Unread 29-01-2010, 16:09
Matt C's Avatar
FRC #1468 (J-Birds)
If that is the case, it seems having a robot that can flip probably isn't the best strategy.
Post the first thing that comes to mind at the sight of the user's avatar above you. clippy Games/Trivia 213 03-07-2011 00:48
Does <R08> prohibit above-bumper extension? BethMo Rules/Strategy 12 07-01-2009 09:20
Stacked Balls above 60" limit? 1574aviad Rules/Strategy 8 19-01-2006 15:57
pic: Galileo from above...WAY above! CD47-Bot Extra Discussion 8 21-04-2004 14:22
The Person Above Me Madison Chit-Chat 53 07-08-2002 07:44
