sample code
Is there anyone that would be willing to share a vi of the arcade motor control with button and/or triggers set up to control two spikes? I am a neophyte with labview and any help would be greatly appreciated
thanks john |
Re: sample code
Also, depending on what you want the Spike to do, you could change the On and Off constants to and of the available values (i.e. Forward, Reverse, On, Off) as desired. |
Re: sample code
thanks much i will give this a try.
john |
| Missing sample code | ajdecker1022 | Java | 3 | 28-01-2010 19:39 |
| Sample Code | Belly | Programming | 1 | 21-01-2010 14:34 |
| Sample Code | Japper | Programming | 2 | 01-12-2008 22:36 |
| Sample PID code??? | EHaskins | Programming | 14 | 08-08-2006 14:18 |
| Is there a sample code? | The Stargazer | Programming | 3 | 17-02-2005 19:22 |
