Go to Post Could you explain this concept of a break from FIRST? Did my wife put you up to this? - Gary Dillard [more]
Unread 29-01-2010, 12:26
Tds123's Avatar
Tds123 Tds123 is offline
There is no I in team =]
AKA: Timothy Shub
FRC #1396 (Pyrobots)
Tds123 is an unknown quantity at this point
Send a message via AIM to Tds123
Programming help go foward but not reverse
Here is my robots code...
http://paste.pocoo.org/show/171676/
The spike that run " winch"
and the spike runs "roller" the button that makes it go foward works but the buttons that make it go in reverse dont work...please help with this someone!!!
and the jaguar for arm... when both buttons are pressed the jaguar turns green one of them is supposed to be red for reverse...
ThE sCaLeS oF bAlAnCe (Team 1396)
Unread 29-01-2010, 16:56
byteit101's Avatar
WPILib maintainer (WPI)
AKA: Patrick Plenefisch
Re: Programming help go foward but not reverse
you are turning it off
if (armjoy.GetRawButton(outtakeButton) == 1) {
			roller.SetDirection(Relay::kForwardOnly);
			roller.Set(Relay::kOn);
		} else if (armjoy.GetRawButton(intakeButton) == 1) {
			roller.SetDirection(Relay::kReverseOnly);
			roller.Set(Relay::kOn);//not kOff
		} else {
			roller.Set(Relay::kOff);
	if (armjoy.GetTrigger() == 1) {
				winch.SetDirection(Relay::kForwardOnly);
				winch.Set(Relay::kOn);
		} else if (armjoy.GetRawButton(winchDownButton) == 1) {
				winch.SetDirection(Relay::kReverseOnly);
				winch.Set(Relay::kOn);//not kOff
		} else {
				winch.Set(Relay::kOff);
Watchdog.Kill();
Help!!! Default programming does not work? WolvesRobotics C/C++ 4 08-02-2009 14:10
URGENT HELP: IR board TRAINS but does not RECIEVE dan_h Sensors 6 20-02-2008 20:31
reverse of motors NOT working please help Stillen Control System 4 11-02-2006 22:05
New to C but not to basic, need help on autonomous cdennisxlx2 Programming 4 02-02-2005 03:38
not robotics, but help would be appreciated pryoplasm Electrical 26 02-06-2004 07:14
