Go to Post If they don't treat Dave nicely, he may just keep his big red ball, and not share with rest of us. - Barry Bonzack [more]
Unread 28-01-2010, 18:38
Jeffy's Avatar
Jeffy Jeffy is offline
Retired, for now
AKA: Jeff Gier
FRC #2410 (Metal Mustang Robotics) #159 (Alpine Robotics)
Jeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant future
Nothing but Dewalts pinion gear
Today I came back from a sucessful hunt at the dewalt service center. I have all the pieces I need to modify and make a gearbox for a fisher price.
In the writeup it does not state how to modify the pinion.
I have two broken dewalt motors with the correct pinions on them. Could anyone tell me how to go about getting the pinion off and then modifiying it to work with the fisher price motor?
Unread 28-01-2010, 19:45
bmusser bmusser is offline
Brian Musser
FRC #1504 (Desperate Penguins)
bmusser has a spectacular aura aboutbmusser has a spectacular aura aboutbmusser has a spectacular aura about
Re: Nothing but Dewalts pinion gear
You can use a gear puller similar to this: http://www.readyheli.com/Universal_P...r_p/acc650.htm
Or
Use and arbor press, support the bottom of the pinion and the rest of the motor unsupported. Press the gear and shaft flush. Use a pin to push the shaft the rest of the way out.
The white paper says the following:
3. Press the modified pinion gear (.125 inch +0.0000" -0.0005 " hole) on the shaft. The distance from the
top of the pinion gear to the front of the motor case is .072 inches, measured with the motor shaft biased
towards the motor. Be careful not to bend this motor shaft. Make sure the shaft is square as you press on
the gear.
The are saying to bore the hole out to .125" no bigger and up to .0005" smaller. Good luck.
Unread 28-01-2010, 19:58
Jeffy's Avatar
Retired, for now
AKA: Jeff Gier
I am no longer at school with the piece so I can't be certain. But, I think the pinion already had a hole larger than .125.
Unread 28-01-2010, 20:04
gren737 gren737 is offline
AKA: Sarah Grenier Montplaisir
Rookie Year: 1995
gren737 has a reputation beyond reputegren737 has a reputation beyond reputegren737 has a reputation beyond reputegren737 has a reputation beyond reputegren737 has a reputation beyond reputegren737 has a reputation beyond reputegren737 has a reputation beyond reputegren737 has a reputation beyond reputegren737 has a reputation beyond reputegren737 has a reputation beyond reputegren737 has a reputation beyond repute
you need to sacrifice another dewalt tranny for a pinion, the pinions from the first stage (the longer ones I think) fit on the FP and will fit in the center of a non-scavengened trans. I think, if it's not the pinion from the first stage it's the second one.
if you read dr. joes' nbd paper it will show you which stage to steal the pinion from.
good luck!
Unread 28-01-2010, 20:21
Brian Musser
You will get the pinion from planet 2 stage. I think there should be 4 gears in stage 2.
Unread 29-01-2010, 16:17
Jeffy's Avatar
Retired, for now
AKA: Jeff Gier
I got the pinion off of the dewalt motor that came with the broken drill. Do the gears in from the second stage have a smaller bore? The bore from the pinion off of the orignal motor is closer to 1/4".
Unread 29-01-2010, 19:08
Brian Musser
Its was 2004 since the last time that I used the Dewalt, but memory tells me that we used one of gears from the planetary stage 2 and bored the center hole to press onto the FP shaft. Not sure about the Dewalt motor pinion. It may be the right size hole. Can't say for sure.
Unread 29-01-2010, 22:02
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
I can't say from memory which stage, but the NBD paper definitely recommends using a planet from one transmission as the sun for the 1st stage.
Joe J.
Team #88, TJ2
Unread 29-01-2010, 22:21
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
Joe J.
From experience I can attest that the pinion you will need comes from the second stage.
We tried endlessly to use one from the first stage to no avail. It simply will not work. We had to remove the newly installed first stage pinion and replace it with one from the second stage, then the motor and trans went together quite easily.
White Paper Discuss: Nothing But Dewalts Joe P Extra Discussion 112 22-01-2010 00:24
[OCCRA]: Nothing But Dewalts Question psquared89 OCCRA 8 31-10-2006 12:06
fisher-price pinion gear bill mc gowan Motors 6 06-03-2006 11:14
Nothing But Dewalts Issue phrontist Technical Discussion 6 01-02-2006 22:38
pic: Nothing but Dewalts ajlapp Robot Showcase 6 09-02-2005 16:41
