Go to Post ...When you use ";"s instead of "."s; darn Java; - machman-2823 [more]
Unread 29-01-2010, 19:08
Kramer 2654 Kramer 2654 is offline
FRC #2654
Kramer 2654 is an unknown quantity at this point
Post Re: How do you get Tank Drive working?
Could you get me directions on how to change the default robot project to use tank drive by replacing and rewiring?
-2654
Unread 30-01-2010, 00:04
I'll assume you know the basics of LabVIEW programming - how to wire, how to get around the palettes.
You need to do two things:
  1. Add another joystick for tank drive
  2. Switch Arcade Drive to Tank Drive
First open/close the joystick:
  • In Begin.vi copy the creation of Joystick 1 and paste it.
  • Change the new joystick open to another USB port
  • Give the new joystick a descriptive new name. e.g., "joystick 2"
  • Wire the error output to the little Build Array box. It can be expanded to expose a new node for wiring.
  • In Finish.vi copy the code for joystick 1 and paste it.
  • Change the name to "joystick 2"
Next switch to Tank Drive:
  • In Teleop.vi, in the inner case statement box select the False case.
  • Remove the axis 1 (x) wire leading to the Arcade Drive
  • Right-click on Arcade Drive, select Replace -> RobotDrive Palette -> Tank Drive
  • Copy the Joystick Get and the unbundled axis box and paste it.
  • Wire the new axis 2 (y) to the Left Axis Value node on Tank Drive
  • Now the new joystick should be added to the Joystick Read vi if you wanted to maintain the style used here, but I'm going to fall back to a simple approach and just have you add it to the left side of the block diagram.
  • Add a Joystick RefNum Registry Get.vi (the one that looks like the # Drive icon) on the far left.
  • Add a constant to the "refnum name" input node and give it the name of your second joystick
  • Wire the output JoystickDevRef through the two case statements to the Joystick Get you added.
Tank Drive vs. Omni Directional Drive jamie_1930 General Forum 9 24-01-2010 22:50
Please Help, Don't Know How to Implement Tank Drive in LabView CVassos NI LabVIEW 5 24-12-2008 16:55
How to get robot to drive straigth using shaft encoders eccmaster Programming 5 02-02-2008 23:50
how do you get new members??? jackie Ha Team Organization 15 09-11-2006 22:15
How do you get ready for Regionals? Kyle Love Chit-Chat 11 13-03-2005 22:49
