Go to Post Thank you GDC, for keeping everyone honest! - dtengineering [more]
Unread 29-01-2010, 19:52
vamfun vamfun is offline
Mentor :Contol System Engineer
AKA: Chris
FRC #0599 (Robodox)
vamfun is a glorious beacon of lightvamfun is a glorious beacon of lightvamfun is a glorious beacon of lightvamfun is a glorious beacon of lightvamfun is a glorious beacon of lightvamfun is a glorious beacon of light
Send a message via AIM to vamfun
Re: Optimizing Precharged Cylinders
OK. Makes sense.
I assume this is a typo and you meant the integral of net force times piston displacement.
Nope Energy=integral( power) and power= F*V
Unread 29-01-2010, 20:08
My bad; I forgot you were integrating with respect to time.
E = integral(F(t)*V(t)*dt)
but also
E = integral(F(x)*dx)
Unread 18-02-2010, 16:00
keericks's Avatar
keericks keericks is offline
AKA: Kent
FRC #1671 (Buchanan Bird Brains)
keericks is a glorious beacon of lightkeericks is a glorious beacon of lightkeericks is a glorious beacon of lightkeericks is a glorious beacon of lightkeericks is a glorious beacon of light
From reading through this thread and the conclusions of preloading the cylinder 1/3 (or so) - does this mean 1/3 of the stroke is deployed (having approx. 1/3 of compressed air in cylinder) OR ...
Does this mean 2/3 of the stroke is deployed (having 2/3 compressed air in cylinder)?
Unread 18-02-2010, 16:43
AKA: Chris
FRC #0599 (Robodox)
The first 1/3(or so) contains compressed air leaving 2/3 of stroke for expansion.
Unread 22-02-2010, 09:49
superdb superdb is offline
FRC #2369
superdb is an unknown quantity at this point
Does anyone know if it is illegal to use a cylinder where you are not utilizing the full stroke distance? For instance using a cylinder with 10" stroke to unlock something where the movement distance is only 2" or so.
Cylinders SamRI Motors 2 30-01-2009 15:56
Optimizing Air Cannon Range Matt H. Pneumatics 34 14-09-2008 20:11
Optimizing rendering Mazin 3D Animation and Competition 2 04-03-2007 18:16
buying cylinders 1574aviad Pneumatics 1 07-02-2006 14:32
Pneumatic Cylinders MASherry Pneumatics 1 09-01-2005 18:49
