Go to Post There can be a fine line between intimidation and inspiration when it come to the elite in FIRST. Those teams who have committed to setting the bar for excellence in ways that change the culture, help to draw that line and deepen it. - JaneYoung [more]
Unread 29-01-2010, 19:52
vamfun vamfun is offline
Mentor :Contol System Engineer
AKA: Chris
FRC #0599 (Robodox)
vamfun is a glorious beacon of lightvamfun is a glorious beacon of lightvamfun is a glorious beacon of lightvamfun is a glorious beacon of lightvamfun is a glorious beacon of lightvamfun is a glorious beacon of light
Send a message via AIM to vamfun
Re: Optimizing Precharged Cylinders
OK. Makes sense.
I assume this is a typo and you meant the integral of net force times piston displacement.
Nope Energy=integral( power) and power= F*V
Unread 29-01-2010, 20:08
My bad; I forgot you were integrating with respect to time.
E = integral(F(t)*V(t)*dt)
but also
E = integral(F(x)*dx)
Unread 18-02-2010, 16:00
keericks's Avatar
keericks keericks is offline
AKA: Kent
FRC #1671 (Buchanan Bird Brains)
keericks is a glorious beacon of lightkeericks is a glorious beacon of lightkeericks is a glorious beacon of lightkeericks is a glorious beacon of lightkeericks is a glorious beacon of light
From reading through this thread and the conclusions of preloading the cylinder 1/3 (or so) - does this mean 1/3 of the stroke is deployed (having approx. 1/3 of compressed air in cylinder) OR ...
Does this mean 2/3 of the stroke is deployed (having 2/3 compressed air in cylinder)?
Unread 18-02-2010, 16:43
AKA: Chris
FRC #0599 (Robodox)
The first 1/3(or so) contains compressed air leaving 2/3 of stroke for expansion.
Unread 22-02-2010, 09:49
superdb superdb is offline
FRC #2369
superdb is an unknown quantity at this point
Does anyone know if it is illegal to use a cylinder where you are not utilizing the full stroke distance? For instance using a cylinder with 10" stroke to unlock something where the movement distance is only 2" or so.
Cylinders SamRI Motors 2 30-01-2009 15:56
Optimizing Air Cannon Range Matt H. Pneumatics 34 14-09-2008 20:11
Optimizing rendering Mazin 3D Animation and Competition 2 04-03-2007 18:16
buying cylinders 1574aviad Pneumatics 1 07-02-2006 14:32
Pneumatic Cylinders MASherry Pneumatics 1 09-01-2005 18:49
