Go to Post To my surprise, purple painted air tanks were illegal last year. AB - Andy Baker [more]
Unread 29-01-2010, 13:49
kham's Avatar
kham kham is offline
K. Ham
FRC #2819
kham is an unknown quantity at this point
Re: HELP FOR THE PARTS ( WHEEL BRACKET)
Originally Posted by Brant Bowen View Post
The 8" Mecanum Wheels should be able to be used with the brackets just by cutting away the aluminum as seen in the picture on the AndyMark website here.
I've seen that picture numerous times, but I can't figure out the best way to deliver power to the wheels. Mounting them inside that bracket doesn't give you enough space to attach a sprocket nor does it provide much flexibility in directing attaching a shaft from a gear box/motor directory to it (Unless I'm just not being creative enough).
Unread 29-01-2010, 20:16
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
I would be VERY careful about adapting the KOP wheel brackets in the manner shown in that picture. If you cut away that much material from the bracket, you are severely compromising the ability of the bracket to resist lateral forces in line with the wheel axle. A lot of testing was done with the bracket/KOP wheel assembly. If the bracket is made of thinner material, or if enough material is removed from the bracket, bad things happen. If the wheel/carpet coefficient of friction is high enough, and the impact energy is high enough, the bracket will bend and fold when the robot is hit from the side by another robot. So let me be real blunt here: don't do this. If you do, you WILL regret it.
-dave
installation for the Wheel Bracket? LANA Kit & Additional Hardware 2 21-01-2010 16:34
Wheel Bracket 2010 in Autodesk Inventor frcchile CAD 2 13-01-2010 14:42
i designed a omni wheel and need help finding money for college vincefitzgerald General Forum 12 19-05-2008 22:03
Bracket for Philly regional anyone? 357_dudeman Regional Competitions 2 27-03-2005 15:28
Thanks for the help and parts, 340! Joe Ross Thanks and/or Congrats 1 22-02-2004 00:09
