Go to Post If they want my business, then they should act accordingly. If they don't, I am quite happy to take my business (and that of my $16.5 billion organization) elsewhere. - dlavery [more]
Unread 29-01-2010, 20:17
coo coo is offline
AKA: Christopher
FRC #0503 (Frog Force)
coo is an unknown quantity at this point
EnhancedIO Exception Error
We are trying to read a potentiometer connected to our Cypress IO board using the enhancedIO class.
Here is our code so far:
package edu.wpi.first.wpilibj.templates;
import edu.wpi.first.wpilibj.IterativeRobot;
import edu.wpi.first.wpilibj.RobotDrive;
import edu.wpi.first.wpilibj.Encoder;
import edu.wpi.first.wpilibj.AnalogChannel;
import edu.wpi.first.wpilibj.DigitalInput;
import edu.wpi.first.wpilibj.DriverStationEnhancedIO;
import edu.wpi.first.wpilibj.DriverStation;
 * The VM is configured to automatically run this class, and to call the
 * functions corresponding to each mode, as described in the IterativeRobot
 * documentation. If you change the name of this class or the package after
 * creating this project, you must also update the manifest file in the resource
 * directory.
public class Team503Robot extends IterativeRobot {
    private RobotDrive drivetrain;
    private Joystick gamepad;
    private Encoder leftDriveEncoder;
    private Encoder rightDriveEncoder;
    private AnalogChannel potentiometer;
    private DigitalInput limitSwitch;
    DriverStationEnhancedIO dseio;
     * This function is run when the robot is first started up and should be
     * used for any initialization code.
    public void robotInit() {
    dseio = DriverStation.getInstance().getEnhancedIO();
     * This function is called periodically during autonomous
    public void autonomousPeriodic() {
     * This function is called periodically during operator control
    public void teleopPeriodic() {
        double slider = dseio.getAnalogIn(1);
We get an "unreported exception edu.wpi.first.wpilibj.DriverStationEnhancedIO.Enha ncedIOException; must be caught or declared to be thrown" error from the "double slider = dseio.getAnalogIn(1); line. Any help would be appreciated.
Unread 30-01-2010, 09:42
bjrussell bjrussell is offline
FRC #1111 (Powerhawks)
bjrussell is an unknown quantity at this point
Re: EnhancedIO Exception Error
Well, it's been a little while since I did Java, but I would guess that the getAnalogIn function can throw an exception, and it's not being handled. You either need a try block around it or you need to declare that it can throw the exception.
Solution 1 (in method):
try {
//additional code to execute if that works
catch (IOException ioexec) {
//do stuff here if it goes wrong
(this last part may or may not be necessary; just know that it will always execute, even if an exception is thrown)
finally {
//more stuff that will always execute
Solution 2:
public void teleopPeriodic() throws EnhancedIOException {
Solution 1 has much better control over what happens if an exception is thrown, so I suggest you use that one in your program. I hope it works for you.
Unread 30-01-2010, 11:09
coo coo is offline
AKA: Christopher
We tried solution 1 and it worked. Thanks for the help.
Wait Exception? NinJA999 Java 3 15-01-2010 14:13
Exception in Timer.cpp Phazonmutant C/C++ 2 17-02-2009 09:27
Target Exception - Exception in Kernal Task Thxe C/C++ 3 10-02-2009 07:24
error - language-plug-in exception... RedOctober45 Programming 1 16-01-2008 15:54
Joystick Exception? Blair Frank Control System 3 09-02-2007 22:41
