Go to Post As goes with all of my advice on CD, try it yourself and make up your own mind. I'm just suggesting things based on experience. See what works for your team. Follow my suggestions to the letter, mix and match them, or even throw them completely out the window. It's all about you and your team. - DampRobot [more]
Unread 08-02-2009, 10:40
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Jaguar Meltdown
Al--With the plastic piece surrounding the pins of each transistor, it looks pretty unlikely that a shaving could short the pins. It might be able to short the mounting tab of one transistor to another, or to some other part of the circuit.
Unread 08-02-2009, 11:02
Re: Jaguar Meltdown
Jim,
It would look that way but on closer examination you will see that the plastic has sufficient clearance between the FETs and the plastic to allow chips to fall into that area. Also the shroud is tapered on the bottom side so most of the pin area is exposed. The shroud only touches the board at the outer edges.
Unread 08-02-2009, 11:07
MrForbes's Avatar
AKA: Jim
Re: Jaguar Meltdown
It's possible, but it still looks unlikely. The openings in the top of the case are very small, the gap between the transistor and the plastic part is very small, so it seems that for a shaving to get in there, it would have to be so small that it would not be large enough to short the pins together. There are other ways for electronic components to fail, than to be shorted by foreign matter, aren't there?
That said, we haven't had any problems, we've been using 4 Jaguars since the end of December. We also haven't been doing any drilling of metal above them, since they're located in a wooden enclosure that is mounted vertically and has it's opening facing away from the rest of the robot.
Unread 08-02-2009, 11:11
Re: Jaguar Meltdown
With the shape of the shroud, there are large open spaces between transistors and lots of turbulent air under the fan to push chunks around and into the FETs along with vibration running hard wheels on hard floors. When in place the underside center of the shroud is almost 1/4" above the board.
Unread 08-02-2009, 13:38
Gdeaver Gdeaver is offline
FRC #1640
Re: Jaguar Meltdown
This may not be debris. This year with the slippery wheels, a jag can go from full forward to full reverse in a very short period of time both electrically and mechanically. This could be a problem with them dealing with back EMF. Does any body know what FET they are using? While modern FETs are tough, the intrinsic diode can be the weak point and when the diode blows FETs look allot like the picture. Didn't the victors have a separate diode to deal with back EMF? Does the Jag? I've noticed that some high power drives that can handle these surges use a special type of MOV to soak up and dissipate the energy from a rapid reversal. Other speed controllers that are used for battle bots warn to allow a time period before applying a reversal. Also, the jags thermal sensing is not part of the FETs and can not react real fast. There are drives that are based on intelligent high side switches that have current and thermal protection built in to the package. It's a more difficult design when using multiple FETS per leg of the H bridge, however they are much tougher. Our team is using a joystick rate of change filter that gives a pronounce decay and ramping up when the driver changes direction rapidly. If jags have the back EMF problem, our filter should help allot.
Unread 08-02-2009, 14:18
Alex Golec Alex Golec is offline
FRC Advocate
no team (FiM Volunteer)
Alex Golec has a reputation beyond reputeAlex Golec has a reputation beyond reputeAlex Golec has a reputation beyond reputeAlex Golec has a reputation beyond reputeAlex Golec has a reputation beyond reputeAlex Golec has a reputation beyond reputeAlex Golec has a reputation beyond reputeAlex Golec has a reputation beyond reputeAlex Golec has a reputation beyond reputeAlex Golec has a reputation beyond reputeAlex Golec has a reputation beyond repute
Re: Jaguar Meltdown
In keeping up with current events, we had the same problem today.
We caught the problem early on, but the Jaguar had already failed at that point. We could smell "warm plastic," and when we disassembled the Jaguar in question, the smell was confirmed: the plastic around one of the FETs had begun to melt.
There were no metal chips to be found, and I have no reason to believe any would have ended up in there. In our testbed, this Jaguar was mounted sideways on a panel above all driven components, and had been opened up fresh out of the box the night before. This was in regular use (http://www.youtube.com/watch?v=FkuxZKA6Cl0).
Hopefully we'll be able to find the source of the problem since this Jaguar is nowhere close to incinerated. I'll be in discussion with Luminary.
Unread 08-02-2009, 16:58
AV_guy007's Avatar
AV_guy007 AV_guy007 is offline
AKA: Sam
FRC #0177 (bobcats)
AV_guy007 has much to be proud ofAV_guy007 has much to be proud ofAV_guy007 has much to be proud ofAV_guy007 has much to be proud ofAV_guy007 has much to be proud ofAV_guy007 has much to be proud ofAV_guy007 has much to be proud ofAV_guy007 has much to be proud ofAV_guy007 has much to be proud of
Re: Jaguar Meltdown
Originally Posted by Urban Hawk View Post
the picture that you had on there is a victor.... not a jaguar. here is a document i found online that may help you:
http://www.robotmarketplace.com/V883UsersManual.pdf
p.s. that is a bad picture of it
That is actually the inside of a jag as stated by others, but more importantly you linked to the Victor 883 manual. While they are similar to the 884 they have differences and are not legal this year. I just wanted to point that out so no one sees that and uses 883's on their robot.
Team 177
bobcat robotics
BLUE ALLIANCE CREW MEMBER
Next event attending: Kickoff 08- Manchester NH With TBA
Unread 09-02-2009, 07:37
Re: Jaguar Meltdown
Gary,
The FET used in the Jaguar is a Fairchild FDP8874. Thanks to Scott and the Luminary folks for being so open and providing schematics and descriptions. HEX Power FETs all have a diode that is a fall out of the manufacturing process as I understand. The Fairchild device has a few better specs than the IFI devices in that the On resistance is a little lower, the current rating is a little higher and the gate switching time is a little faster. The diode is speced for a voltage drop at 40 amps so I would guess the diode can handle more than that. With three in parallel, they should handle any current the motor could back feed into them during a motor reversal.
In the one post above about a single FET melting the plastic, I would suspect that the one device had just reached the temperature of the plastic melting point while the others were not far behind. This could easily be a difference in cooling fan flow or contact with the transistor tab. Remember that the IFI Victor did not contain plastic near the transistors so users would have nothing to indicate that the devices were at elevated temperatures without touching them. Luminary is trying to research all the data from the field so it is important to report as much data as you can about the device and it's use at the time of failure. This is a daunting task to sift through what might be actual failure from what might be abuse. Remember that we have had abusive failures every year we have used IFI components. Try as they might, manufacturers can only try to design to minimize abusive failures. There is significant diminishing returns to this equation though. "Make it foolproof and only a fool will use it", as the old saying goes.
Unread 29-01-2010, 16:52
Team2191 Team2191 is offline
FRC #2191 (Fluxcore)
Team2191 is an unknown quantity at this point
Re: Jaguar Meltdown
Where should we send broken Jaguars?
Unread 29-01-2010, 18:27
the man's Avatar
the man the man is offline
AKA: Jacob Overla
FRC #4004
the man is on a distinguished road
Re: Jaguar Meltdown
Dont take the conecter screws all the way out they can get metal shavings in there wich is most likly what happened. It happened to us twice last year and other teams with six of them had no problems, we were taking the screws all the way out and it would scrape some of it off leaving metal shavings in the jags...Not fun stuff.
Every day is a new adventure!!!
Unread 29-01-2010, 19:05
zahara3 zahara3 is offline
FRC #0007
zahara3 is an unknown quantity at this point
Re: Jaguar Meltdown
can some one tell me if we are still allowed to use victors or not? thank you
Unread 29-01-2010, 19:46
seannoseworthy's Avatar
seannoseworthy seannoseworthy is offline
FRC #2200 (MMRambotics)
seannoseworthy is a splendid one to beholdseannoseworthy is a splendid one to beholdseannoseworthy is a splendid one to beholdseannoseworthy is a splendid one to beholdseannoseworthy is a splendid one to beholdseannoseworthy is a splendid one to behold
Send a message via MSN to seannoseworthy
Talking Re: Jaguar Meltdown
You can find instructions here on how to RMA a jaguar.
We had this exact same problem last year. In the report Luminary Micro released. They say the problem is Excessive heat in MDL‐BDC MOSFET(s) with the symptoms of Excessive current draw by MDL‐BDC with the visuals of Single low‐side MOSFET melt‐down with damage to plastic ring Possible blown or fractured PCB traces. To prevent this Luminary Micro reccomends Mitigate risk for swarf (for example, avoid using ring terminals; take extreme precaution when creating metal debris), avoid positioning module for direct impact vulnerability during competition.
Two days ago we had another Jaguar fail the status led flashed red and BDC-COMM reported a VOLTAGE BUS error. Which is most likely "Voltage regulator Failure (REG): Failures of the 3.3 V or 5.0 V linear regulator could be due to one of two conditions. The most likely root cause is excessive current draw from the power rail at the interface connector. The regulator is specified to shut down internally under these conditions; however, our testing has shown that this regulator feature does not work correctly. The second possible root cause is input over-voltage. The regulators have a maximum input voltage of 15 V, which is reflected in the absolute maximum rating of the Jaguar module. Bench tests have shown that the regulators function beyond 15 V with no degradation or failures at less than 17 V. Although there is no measured data showing DC supply voltages greater than 15 V, there is speculation that the supply could exceed this under certain regenerative conditions. Efforts to replicate this failure on the bench using a motor in full-regeneration were unsuccessful. Despite lack of correlation with bench testing, this is the only reasonable explanation for certain regulator failures, and because of the range of installations, not every condition can be reasonably replicated. Luminary Micro will use a regulator with an increased voltage range and functional over-current protection in future revisions of this design."
-Sean
Unread 29-01-2010, 20:45
Dad1279 Dad1279 is offline
FRC #1279 (Cold Fusion)
Re: Jaguar Meltdown
We bricked one tonight just updating the firmware.
We really wanted to take advantage of the features this year but the reliability is frustratingly unacceptable.
Ready to throw on the towel and dust of the reliable 5 year old vics....
Unread 29-01-2010, 21:28
Re: Jaguar Meltdown
Yes, you may use Victors. From Sec 8, Rev E
<R42> Items specifically PROHIBITED from use on the ROBOT include:
D. Motor speed controllers other than Innovation First, Inc. “Victor 884” speed controllers or Luminary Micro/Texas Instruments “Jaguar” (MDL-BDC or MDL-BDC24) speed controllers,
Unread 29-01-2010, 22:45
If the firmware is corrupt, you may be able to fix it with the JTAG port on the bottom of the device it will be coverd by the sticker. Flash it with the newest firmware found here. You would want to use this cable or a similar cable to flash the firmware.
PM me if you want to sell me your jaguar with corrupt firmware
-Sean
Jaguar CAD Patrickwhite Inventor 2 24-01-2009 14:07
Jaguar Failure Nightfall831 Electrical 8 21-01-2009 10:12
Jaguar Fried? Sovietmagician FRC Control System 0 19-01-2009 23:27
Control System Meltdown Kory FRC Control System 7 17-01-2009 15:59
Jaguar Problem Sauce Electrical 7 10-01-2009 14:28
