Go to Post Hmmm I think I hear phones ringing. Panic calls to the Rules committee to figure out how to close THAT loophole, which you could drive a truck through. Have you considered a career in Law? - ChrisH [more]
Unread 29-01-2010, 20:50
frcchile's Avatar
frcchile frcchile is offline
FRC #2576
frcchile will become famous soon enough
Prototype FRC Chile
Hello Look our prototype
http://www.youtube.com/watch?v=aVknAGl5Ch4
http://www.youtube.com/watch?v=dtl04IAYu0E
http://www.youtube.com/watch?v=nw9bjccs_JQ
Thank you!!
Unread 29-01-2010, 21:14
Jones571's Avatar
Jones571 Jones571 is offline
AKA: Corey
FRC #0571 (Paragon)
Jones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud of
Send a message via AIM to Jones571
Re: Prototype FRC Chile
Nice progress!
Unread 29-01-2010, 21:24
ebarker's Avatar
ebarker ebarker is offline
AKA: Ed Barker
FRC #1311 (Kell Robotics)
ebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond repute
FAILS Inspection !!!!!
You have 5 CIM motors. Only 4 are allowed.
You don't need 2 CIMs per transmission. That power output is quite likely to exceed your ability to transfer it through those wheels onto the ground.
Even if 5 CIMs were allowed you only have 3 Jaguars. The has to be a one to one correspondence between each CIM and Jaguar.
If you remove 1 each CIM from each transmission then you will be ready to pass inspection.
Other than that things look great. How does your kicker work ?
Good Luck !!
Ed Barker
Unread 29-01-2010, 21:26
Jones571's Avatar
AKA: Corey
FRC #0571 (Paragon)
Good Luck !!
that would mean you fail are reading the manual this year you can have 5 CIMs on your robot
<R52> Motors specifically permitted on 2010 FRC ROBOTS include:
A. All motors, actuators, and servos listed in the 2010 KOP,
B. An unlimited number of COTS servos with a maximum output torque of 55 oz-in and maximum rotational speed of 100 rpm at 6 Vdc (e.g. HITEC model HS-322HD or HS-325HB servos, as provided in the KOP),
C. An unlimited number of FIRST Tech Challenge (FTC) servos (HITEC HS-475HB servos),
D. One, two, or three additional 2½” CIM motors (part #FR801-001 and/or M4-R0062-12) in addition to those provided in the KOP. This means that up to five, and no more, 2½” CIM motors can be used on the ROBOT.
Unread 29-01-2010, 21:35
Carrara Carrara is offline
1860, my life
FRC #1860 (Cephatron)
Carrara is an unknown quantity at this point
Send a message via MSN to Carrara
oh yeah
you can use 5 cims, on the robot
you are using 2 cim motors for each wheel, your main intention is to have a wonderfull torch?
have you tried with 1 cim motor for each wheel???
the robot looks great, specially, because it can pass easily on the bumps
thats good
go teams
Unread 29-01-2010, 21:58
ebarker's Avatar
AKA: Ed Barker
I stand corrected - epic fail on the motor count !! My humble apologies.
But the jag count is still wrong.
Mmmm, 5 CIMs, seriously interesting...
Ed
Ed Barker
Unread 29-01-2010, 22:08
sloteera's Avatar
sloteera sloteera is offline
AKA: Rafa
sloteera has much to be proud ofsloteera has much to be proud ofsloteera has much to be proud ofsloteera has much to be proud ofsloteera has much to be proud ofsloteera has much to be proud ofsloteera has much to be proud ofsloteera has much to be proud ofsloteera has much to be proud ofsloteera has much to be proud of
Hooola hermanos latiino americanos!!
I wish a good luck to you guys in LA this year.
Nice kicker, but, you must be agree with me: Valdívia, El mago, kicks muuuch better!!! hahahaha
Unread 29-01-2010, 22:16
Derschatten Derschatten is offline
FRC #1203 (Pandemonium)
Derschatten is an unknown quantity at this point
No, their is four Jag the other one is near the brain. you can see it in the video when the robot is coming down the bump.
The Jag rule he was talking about was having one Jag run two motor.
Unread 30-01-2010, 00:49
joek's Avatar
joek joek is offline
Team Welder and CAD tech
FRC #2052 (KnightKrawler)
joek is an unknown quantity at this point
there's also victors
2012 Record (13-2-0)
lake superior regional finalists- thank you WAVE (2826) and Blue Twilight (2220)
Unread 30-01-2010, 05:57
ebarker's Avatar
AKA: Ed Barker
"EPIC FAIL" I say as I walk off in total defeat !!!!
We it is good that everyone has had a close look and got this team out of inspection.
Ed Barker
Unread 30-01-2010, 07:06
GaryVoshol's Avatar
Cogito ergo arbitro
I see other potential inspection issues. In the video of the robot going over the bump, stop it at 5 seconds. It looks like the wheels are outside the FRAME PERIMETER. Certainly the kicker is outside the FRAME PERIMETER, as are parts of the foam padding.
(since 2004)
Unread 30-01-2010, 12:13
Looking good my friends! I like the kicker, simple and effective.
Nice call Gary.
We do have to remember the title of the article. Prototype is in there. So it would appear the proto is working, now on to the competition version.
Unread 30-01-2010, 17:12
frcchile's Avatar
FRC #2576
We agree jajajjajaj Valdivia is one of the best soccer player for this worl d cup
Thanks for the replays
Unread 30-01-2010, 19:03
sloteera's Avatar
AKA: Rafa
Okay okay,this is a true fact!!!
Buuuuuuut, Kaka and Luis Fabiano (ex soccer players of São Paulo) will destroy in the world cup this year!!!
Unread 01-02-2010, 11:14
lynca's Avatar
lynca lynca is offline
Andrew Lynch
FRC #2587 (DiscoBots)
Thank you!!
What ratio are you running on your toughbox mounted to the kicker ? The standard 12.75 : 1 or something else ?
History: 624 - Cryptonite --> 118 - Robonauts --> 2158 - AusTIN CANS --> 2587 DiscoBots
Bio: Andrew Lynch "How I Work" ---- LinkedIn , Facebook, Twitter
Help team of Chile frcchile Team Organization 7 22-11-2009 15:09
Team 241's Turret Prototype ontop of the Harvester Prototype Dantvman27 Robot Showcase 39 08-02-2009 22:53
TEAM 2576 from CHILE needs your help! Scott Sedam General Forum 0 08-03-2008 19:48
pic: FRC 1726 Steering Prototype MrForbes Extra Discussion 15 12-01-2008 21:21
**FIRST Email**/FRC Online Survey and FRC Team Forums AmyPrib FIRST E-Mail Blast Archive 4 28-03-2006 13:07
