Go to Post The Tekin's used to constantly suffer from spontaneous combustion, it was extremely frustrating how often they would go. - Kingofl337 [more]
Unread 29-01-2010, 22:24
RKElectricalman's Avatar
RKElectricalman RKElectricalman is offline
Meezy the Mentor
AKA: Rameez
FRC #0384 (Sparky 384)
RKElectricalman is just really niceRKElectricalman is just really niceRKElectricalman is just really niceRKElectricalman is just really nice
Send a message via AIM to RKElectricalman
Question Camera Target size configuration
We've been fooling around with the Target.cpp and Target.h files to understand enough of it to see how the code determines the size of the target. After a good hour of reading through, and fact checking, we couldn't really figure out how the values in Target.cpp correspond to the real life values of the target.
Does anyone know how the values of Major radius min and max, and minor radius min and max relate to the actual 38 inch diameter of the real life target?
The question is for understanding AND application, and any help you give us will help us greatly now and in the future.
Thanks!
Meezy
ahhh Division Finalists!!
Unread 30-01-2010, 08:13
Bongle's Avatar
Bongle Bongle is offline
FRC #2702 (REBotics)
Re: Camera Target size configuration
Major/Minor radii are measured in pixels in the cameras field of view. The camera's field of view is about 44.5 degrees. With that knowledge (and an assumption that each pixel takes up an equal # of degrees), you can compute how many pixels the 38 inch target will take up at whatever distance you're trying to optimize for.
It takes a bit of trig, but it's not tough to do.
See the attached image for a diagram.
Unread 30-01-2010, 17:47
Meezy the Mentor
AKA: Rameez
wow, that was very helpful! Thank you!!
I should've thought about that, pixels... hmm
and i'm guessing the max pixels have to be less than the camera's resolution?
Unread 03-02-2010, 15:13
DjMaddius's Avatar
DjMaddius DjMaddius is offline
AKA: Matt Smith
FRC #2620 (Southgate Titans)
DjMaddius is an unknown quantity at this point
They could be the same or smaller than.
The cameras resolution is actually how many pixels by pixels it sees.
Camera Target Dimensions pribusin General Forum 8 13-01-2010 13:29
Target acquisition with camera- color issues Quarkster Programming 20 12-03-2009 00:11
Camera Tracking Target Jade Programming 3 20-01-2007 01:41
Urgent help needed : Camera locks on to no apparent target! ?!?! Salik Syed Programming 11 06-03-2006 17:24
