Go to Post MAKE SURE THE BATTERY DOES NOT FALL OUT - magnets [more]
Go Back   Chief Delphi > FIRST > Career
Unread 29-01-2010, 21:47
alstonfered alstonfered is offline
Junior Member
alstonfered is an unknown quantity at this point
Which is better for my future?
Hi friends,
I an student of engineering field.I am just confuse about the language selection for web designing programming.Please suggest me that which language should i choose??
I have two options in my mind,and they are "Java or .Net"....
Which should i select??If you have any other better option then please suggest it too.
Thank you in advance for your reply..
Unread 29-01-2010, 21:49
jamie_1930's Avatar
jamie_1930 jamie_1930 is offline
FRC #2228 (Cougartech)
Team Role: Student
jamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to behold
Re: Which is batter for my future?
Originally Posted by alstonfered View Post
Hi friends,
Start off with English.
Team 2228(FRC) - Drive Team Lead, Drive Coach, Mechanical Team
Team 3750(FTC) - Team Lead
2009
Team 2228(FRC) - Mechanical Team, Driver at RIT, and Hartford Regionals, and Drive coach at Ruckus
*Second Place at Ruckus
Team 3750(FTC) - Team Lead, and Drive coach at Clarkson Regional
*Second Place at Clarkson Regional
2008
Team 1930(FRC) - Worked on Mechanical, Electrical, and Programming.
Unread 29-01-2010, 23:22
Derschatten Derschatten is offline
FRC #1203 (Pandemonium)
Derschatten is an unknown quantity at this point
I think I understand the question.
So for building website or web application. Your flavors of choice are:
Java, C# , VB.NET, ColdFusion, Perl, PHP, Python , Ruby and, Lua .
Packages:
LAMP/WAMP/MAMP(Linux/Window/Mac, Apache, MySQL, PHP/Python/Perl)
Most people who use this set choose PHP.
Ajax)(Asynchronous, JavaScript, XML)
ASP.Net(Active Server Pages)
*Sorry if any links are broken or in the wrong spot.
I would Suggest you also check out the follow information.
Web 2.0
Zend This has to do with PHP.
Yahoo Developer Network
Google Web Toolkit
I usually use PHP+MYSQL with a CSS layout.
If you wanted you could use all of the above most of them will talk to each other.
Unread 30-01-2010, 13:50
RookieWookiez's Avatar
RookieWookiez RookieWookiez is offline
Scouting Student Leader
AKA: Dane Potter and Others
FRC #3138 (Innovators)
Team Role: Scout
RookieWookiez is an unknown quantity at this point
I'm not sure what exactly is your strong point, but before the season began my team had a little programming class thingy, and I learned one thing: "Java can't be used to build Killer Robots." Not sure if that'll help, but I thought I'd throw it out there.
Unread 30-01-2010, 17:39
DonRotolo's Avatar
Back to humble
FRC #0832
What this quote is trying to tell you is this: If there was ONE big thing that would help you in your entire future career it would be to learn to communicate in English without mis-spellings, grammatical errors, and other basic errors.
When I was a hiring supervisor, any resume' that came to me with errors was recycled without further consideration. I do not care how well you can speak; all important communications occur in writing. Being able to read and write in English is quite high on my list of priorities when considering someone to hire, and I doubt this attitude is unique.
Now, it may be that your first language is not English. If this is true, then it indicates that you need to put some effort into the language, if you expect to have a career that deals with the English-speaking world. Not that English is all that simple; I find it to be a difficult language, but mastering it completely will serve you far better that being excellent in Java or .NET.
Programming languages can be learned and mastered in a few months. English can take more than a lifetime. Best get started soon.
Auch, du kannst auf Deutsch schreiben, falls noetig.
Last edited by DonRotolo : 30-01-2010 at 20:29. Reason: ein bisschen Deutsch, warum nicht?
Unread 30-01-2010, 20:06
gvarndell's Avatar
gvarndell gvarndell is offline
Software Engineer
AKA: Addi's and Georgie's Dad
FRC #1629 (GaCo)
Team Role: Parent
gvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond repute
I think that's all but certain.
Mastered?
I wanna meet the programmers you know.
Robots never, ever, ever, ever break -- The Robot Repairman (Backyardigans)
Unread 30-01-2010, 20:23
Karibou Karibou is offline
Steel is love. Steel is life.
AKA: Kara Bakowski
FRC #0341 (Miss Daisy)
Karibou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond repute
Send a message via AIM to Karibou
I'm inclined to say that the user's first language is not English. Look at the link in their signature - it's a .at link, which is the country code for Austria. The web page is also written in German.
I was just a little bit shocked at the response to the somewhat-broken English. When a Chilean team posts asking a question with improper grammar and usage, everybody is kind and understanding, even if the intent of the post isn't clear, but when it takes more than a few seconds to understand the intent of the post, we get a little snippy about it? I'm seeing a double standard , but that may have just been me interpreting the above posts with the wrong tone. Take a trip back to high school...I doubt that my Italian is anywhere near grammatically correct, and we all struggled with foreign languages at some point. This is no different. We also speak with incredible amounts of slang, even though we don't realize it.
My interpretation of the post, in slightly more understandable English:
I am an engineering student, and I am just confused about the language selection options for web design programming. Do you have any suggestions about which language I should choose to use?
The two options that I'm thinking of are Java or .Net
...which one should I choose? If you have any better options, then I'm open to suggestions.
Thanks in advance for your reply
Also, welcome to CD, alstonfered.
Kara Bakowski
Michigan Technological University///Materials Science and Engineering '15///Go Huskies! #tenacity
kabakowski(at)gmail(dot)com
FRC 341 (2016-present): Mechanical/build mentor
Volunteer (2010-present): MAR Seneca '17, FTC Hat Tricks Qualifier '16, Brunswick Eruption '16, MAR Montgomery '16, MAR Westtown '16 Portcullis Victim, MAR Springside-Chestnut Hill '16, Ramp Riot '15 '16, FiM Escanaba District '14 '15, MidKnight Mayhem '13 '15 '16, FiM Detroit District '13, IRI '10 '12, FiM Waterford District '11 '12, MARC '12, CMP Galileo '11
FRC 1189 (2008-2011): Team Captain, Pit Crew, Website group leader, Team Education group leader, Proud Alum. We've got spirit, yes we do...
WMWBS '10 '11
Unread 30-01-2010, 20:29
gvarndell's Avatar
Software Engineer
FRC #1629 (GaCo)
Team Role: Parent
Originally Posted by Karibou View Post
I'm inclined to say that the user's first language is English. Look at the link in their signature - it's a .at link, which is the country code for Austria. The web page is also written in German.
No doubt, you meant "not English"?
Unread 31-01-2010, 10:00
gvarndell's Avatar
Software Engineer
FRC #1629 (GaCo)
Team Role: Parent
I think the terse response by the student was uncalled for, otherwise nothing shocking.
But I would just chalk the student's response up to youth and inexperience.
We eventually get to the point that we can read bad English and make a reasonably accurate guess as to whether it's bad because the writer doesn't have English as his first language or because the writer is just not-so-bright.
I think the reply by Mr. Rotolo was entirely considerate and offered appropriate advice to anyone who aspires to become employed IN the US.
Presumably though, the poster will make out just fine with his limited English skills in Germany or Austria or wherever he actually lives.
Edit:
It occurs to me that, if one does not have English as the first language, and one doesn't wish to preface each post with an apology for that fact (I wouldn't if it were me), then it might not hurt to put something about it in one's signature.
Something like "English is not my first language. Please be kind about my grammar"
Unread 31-01-2010, 17:06
SteveGarward's Avatar
SteveGarward SteveGarward is offline
Red 5, standing by...
AKA: 7 years already
FRC #0111 (WildStang), FRC #3132 (Thunder Down Under)
SteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud of
In my experience, the answer to your question (original post) is basically this:
Learn the principles, and then choose the best tool for the job.
Java is great for web application development. .Net is Microsoft's answer to Java. JSP/ASP let's you write web pages that also include code for more complex web pages and applications. Javascript is a scripting language which can either make things easy or quite hard. PHP is a scripting language for web development. Any Web 2.0 stuff is going to (largely) require some Javascript knowledge...
I would say pick a starting point, learn the principles, and then be able to branch out to other languages and toolkits. My recommendation would be: start with HTML, Javascript and styles. Once you want to get into programming more for complex web applications, start with one (say, Java or JSP), and then try the others to see how they do the same things.
FRC Team 111 - WildStang (Mentor, Drive Coach)
FTC Team 7458 - Full Force! (Mentor, Coach)
FRC Team 3132 - Australia's FIRST FRC Team! (Holy crazy first year, Batman!)
Unread 31-01-2010, 18:41
Alex Cormier's Avatar
Alex Cormier Alex Cormier is offline
www.TwoPencilDesigns.com
AKA: Grizz, Twinkletoes, PitBull1126
FRC #1405
Alex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond repute
REPORTED.
http://www.google.com/search?source=...&aq=f&aqi=&oq=
Two Pencil Designs - Vinyl Graphics, Bumper Numbers, and Strategy Items!
Like us on Facebook & follow us on Twitter
Facebook.com/TwoPencilDesigns & TwoPencilDesign
Unread 01-02-2010, 08:35
gvarndell's Avatar
Software Engineer
FRC #1629 (GaCo)
Team Role: Parent
Originally Posted by Alex Cormier View Post
REPORTED.
Well shoot! We've all been snookered by a spammer.
Unread 01-02-2010, 22:30
-42-'s Avatar
-42- -42- is offline
Bangs His Head in Polyrythyms
AKA: *****
FRC #1388 (Eagle Robotics)
Team Role: CAD
-42- is an unknown quantity at this point
Send a message via AIM to -42-
On the upside it wasn't a pron-bot.
Those really mess with the FIRST image.
Unread 02-02-2010, 08:16
lenny8's Avatar
lenny8 lenny8 is online now
Aww Yea
AKA: L-Deezy
FRC #1018 (Robodevils)
lenny8 is a splendid one to beholdlenny8 is a splendid one to beholdlenny8 is a splendid one to beholdlenny8 is a splendid one to beholdlenny8 is a splendid one to beholdlenny8 is a splendid one to beholdlenny8 is a splendid one to behold
good eye. i knew this looked familiar.
Learn something, Know Something, Do something
Unread 02-02-2010, 19:32
spacegy4's Avatar
spacegy4 spacegy4 is offline
Is a CAD
AKA: Andrew Sternglass
FRC #0639 (Code Red Robotics)
spacegy4 is a name known to allspacegy4 is a name known to allspacegy4 is a name known to allspacegy4 is a name known to allspacegy4 is a name known to allspacegy4 is a name known to all
Send a message via AIM to spacegy4 Send a message via MSN to spacegy4 Send a message via Yahoo to spacegy4
I'm surprised that anyone would not realize it was a spammer. Its sig says buy in it and links to a website that isn't in english.
"When you pull the project out of the fire and make the robot dance, thats real education."
Woodie Flowers: 2010 Kickoff
Future animation leader asking for help 16MentalTempest 3D Animation and Competition 12 10-03-2009 02:51
In order to ensure a F.I.R.S.T future for Southgate corcarter General Forum 3 31-03-2008 13:33
Suggestions For Future Championship Events vadyr Championship Event 3 16-04-2007 22:53
pic: team 842 batter with mount falconmaster Robot Showcase 10 05-02-2006 10:57
Another idea for future competitions archiver 2001 13 24-06-2002 03:33
