Go to Post The final product, the inspiration, it all that matters. Awards and championships are just bling. - artdutra04 [more]
Unread 01-20-2010, 08:49 AM
1711Raptors 1711Raptors is offline
FRC #1711
1711Raptors is an unknown quantity at this point
WindRiver lockup/freeze on compile
Did not affect us in 2009, but our updated 2010 WindRiver compilation process locks up in a wait state when processing the MakeFile. The offending command is the piping through tclsh for that generated C file. It creates the file OK, but then fails to move on. Googling turns up a known problem with the Cat'ing of the pipe into tclsh and the termination of tclsh once the redirection is performed. If I look at taskmanager, tclsh is still running (blocked) and so the compile process cannot continue. Terminating the process does nothing (it does not respond to termination events - interesting) so the compile never completes.
I have removed the entry in the makefile script line just to prove this is the issue and behold it compiles. I know this will come back to bite us as I am sure the generated C file is ultra important.
This has to be unique to us as it would halt everyone running WindRiver but - anyone else seen this behavior? The last compile process output is 'Building <your projectname>.out' then nothing more than a stalled compile process.
I notice the WindRiver update on the usfirst.org site and I will have to check if that has been applied.
Cheers!
Unread 01-21-2010, 08:06 AM
FRC #1711
Re: WindRiver lockup/freeze on compile
New machine, new install, no problem ... has to go into the 'memories' bin.
Unread 01-22-2010, 03:26 PM
masoug's Avatar
masoug masoug is offline
Food Consumer
FRC #0114
masoug is an unknown quantity at this point
Well, did you run the updater?
JabbaScript
Unread 01-27-2010, 05:55 PM
rjn rjn is offline
rjn is an unknown quantity at this point
Weirdest thing happened to ours. After some troubles with no code, we finally fixed our problems and were download and running code. And then from what seems like out of the blue, the compiler started to hang at 52%, no matter what we do. Which was weird being that on the same instance of windriver, we had only like 30 minutes before compiled and downloaded working code to our robot. And after 2 fresh installs, updates and all, it still hangs at 52%.
Unread 01-27-2010, 06:40 PM
masoug's Avatar
Food Consumer
FRC #0114
What OS are you running?
JabbaScript
Unread 01-27-2010, 06:50 PM
rjn rjn is offline
Vista home.
Unread 01-27-2010, 07:50 PM
Bryan Herbst's Avatar
Bryan Herbst Bryan Herbst is offline
AKA: Bryan
FRC #2052 (KnightKrawler)
Bryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond repute
Update- We simply reloaded the simple template and added our own code back in. It magically compiled again.
Team 2052- Knightkrawler
Mentor and volunteer
Unread 01-27-2010, 08:28 PM
rjn rjn is offline
And now it doesn't.
Unread 01-30-2010, 12:43 AM
joek's Avatar
joek joek is offline
Team Welder and CAD tech
joek is an unknown quantity at this point
durgin, u need to quit borking stuff
2012 Record (13-2-0)
lake superior regional finalists- thank you WAVE (2826) and Blue Twilight (2220)
Foley Freeze on front page GaryVoshol FIRST In the News... 1 03-30-2009 01:13 AM
Periodic System Lockup GabeRC1717 C/C++ 3 01-21-2009 06:31 AM
pic: Foley Freeze doubles up jgannon Extra Discussion 25 10-08-2007 07:53 AM
Where to buy Freeze spray? Jeff Waegelin Technical Discussion 19 03-13-2007 08:51 PM
CMU Cam Freeze-ups Schneidie Programming 2 03-16-2006 08:31 PM
