Go to Post ...there's no easier way to get something changed than to have it happen on FIRST's biggest stage. - Billfred [more]
Unread 18-08-2002, 21:37
Gui Cavalcanti's Avatar
Gui Cavalcanti Gui Cavalcanti is offline
Robogeek
Gui Cavalcanti is a name known to allGui Cavalcanti is a name known to allGui Cavalcanti is a name known to allGui Cavalcanti is a name known to allGui Cavalcanti is a name known to allGui Cavalcanti is a name known to all
Send a message via AIM to Gui Cavalcanti
We had that sort of problem in 2001 with Peacemaker. This is what we ended up doing:
http://www.chiefdelphi.com/forums/pi...&quiet=verbose
That little red strip under the lexan panel is a piece of plywood that was cut for our timing belt. It puts pressure on the entire length of the belt, is easy to do, and doesn't require much time to machine. Of course, it is crude, but the belt has never cut into the plywood (just got worn off by carpet). We attached aluminum angle to the side of our chassis and flat-head-screwed the plywood into the angle pointing down.
We've never had to replace it since the 2001 season started, and it's worked very well. I suppose Teflon would work better, though.
Gui Cavalcanti
All-Purpose College Mentor with a Mechanical Specialty
Franklin W. Olin College of Engineering, Class of 2008
weight distribution? chrisw Technical Discussion 3 11-01-2003 13:25
Tank treads and specialty wheels archiver 2001 7 24-06-2002 01:25
Lots of Wheels and F = u x N archiver 2001 17 23-06-2002 23:37
Quad- 1/2 track drive system Ben Mitchell Technical Discussion 24 30-01-2002 11:55
