Go to Post I'm gonna laugh when the GDC numbers the first official game hint #3. - Racer26 [more]
Unread 30-01-2010, 06:12
gyaniv's Avatar
gyaniv gyaniv is offline
AKA: Gutman Yaniv
FRC #2230 (General Angels)
gyaniv has a spectacular aura aboutgyaniv has a spectacular aura about
Ball possession
According to the rules only one ball can be possessed and be 3" inside the robot frame.
But, can more then one ball be inside the 3" restriction if still only 1 ball is possessed?, or this is also forbidden?
FRC Team 2230 - Student - 2009-2011
FRC Team 2230 & 4406 - Mentor - 2012
FRC Team 2230 - Mentor - 2013-present
"A mentor's job is to understand what the students are trying to make, and bend the laws of physics to make that happen"
Unread 30-01-2010, 06:47
Austin2046's Avatar
Austin2046 Austin2046 is offline
Design, Strategy & Scouting Mentor
FRC #2046 (Bear Metal)
Austin2046 has a spectacular aura aboutAustin2046 has a spectacular aura about
Re: Ball possession
POSSESSION: Controlling the position and movement of a BALL. A BALL shall be considered in POSSESSION if, as the ROBOT moves or changes orientation (e.g. backs up or spins in place), the BALL remains in approximately the same position relative to the ROBOT.
i would say that intentionally having a 2nd ball within 3inches of your frame perimeter would be considered possession. like if u have 2, kick the first one then kick the second... u controlled the position of the 2nd one while in possesion of the 1st... incedental contact inside of the frame perimeter should be allowed however. like ur holding one and another rolls into ur frame perimeter... but just like bounces off or moves away when u turn or back up then ur fine.
Unread 30-01-2010, 07:00
GaryVoshol's Avatar
Cogito ergo arbitro
Re: Ball possession
BALL POSSESSION is independent of the 3" rule.
<G43> ROBOT BALL POSSESSION - ROBOTS may POSSESS only one BALL at a time. Violation: PENALTY.
<G46> BALL Penetration Restriction – The BALL must not extend more than 3 inches inside the FRAME PERIMETER as defined in Rule <R19>. Violation: PENALTY for a basic infraction, plus a YELLOW CARD if no immediate attempt to remedy.
You could violate <G46> without POSSESSING the BALL. Or you could violate <G43> without violating <G46>. <G46> is about location, not POSSESSION.
(since 2004)
Unread 30-01-2010, 08:27
ttldomination's Avatar
Sunny
Re: Ball possession
I believe Mr. Voshol is correct. If you have like 5 balls under your robot, and all five are only 3" into the robot perimeter, but you are only *controlling* the position of one of those balls, say through a roller or suction, then only one of those balls is in your "possession" and you're 100% legal.
1648: 2013-2014
5283: 2015
Hearding VS Possession Stevenof2619 Rules/Strategy 11 12-01-2010 22:31
ROBOT BALL POSSESSION Hito Seika Rules/Strategy 2 11-01-2010 22:45
WHere do you get Ball Casters/ BAll Transfers for FRC?!?!?!? leehyungjin4u General Forum 3 15-01-2008 23:27
Possession of trackball Nothing551 Rules/Strategy 4 14-01-2008 23:01
Rule Discussion: Possession Pavan Dave Rules/Strategy 28 12-03-2007 16:27
