Go to Post There can never be enough help, unless there's too much help. - Joshua May [more]
Unread 30-01-2010, 06:47
Austin2046's Avatar
Austin2046 Austin2046 is offline
Design, Strategy & Scouting Mentor
FRC #2046 (Bear Metal)
Austin2046 has a spectacular aura aboutAustin2046 has a spectacular aura about
Re: Ball possession
POSSESSION: Controlling the position and movement of a BALL. A BALL shall be considered in POSSESSION if, as the ROBOT moves or changes orientation (e.g. backs up or spins in place), the BALL remains in approximately the same position relative to the ROBOT.
i would say that intentionally having a 2nd ball within 3inches of your frame perimeter would be considered possession. like if u have 2, kick the first one then kick the second... u controlled the position of the 2nd one while in possesion of the 1st... incedental contact inside of the frame perimeter should be allowed however. like ur holding one and another rolls into ur frame perimeter... but just like bounces off or moves away when u turn or back up then ur fine.
Hearding VS Possession Stevenof2619 Rules/Strategy 11 12-01-2010 22:31
ROBOT BALL POSSESSION Hito Seika Rules/Strategy 2 11-01-2010 22:45
WHere do you get Ball Casters/ BAll Transfers for FRC?!?!?!? leehyungjin4u General Forum 3 15-01-2008 23:27
Possession of trackball Nothing551 Rules/Strategy 4 14-01-2008 23:01
Rule Discussion: Possession Pavan Dave Rules/Strategy 28 12-03-2007 16:27
