Go to Post You can build an amazing robot that is capable and beautiful on a limited budget. - Andy Baker [more]
Unread 01-30-2010, 07:33 AM
gvarndell's Avatar
gvarndell gvarndell is offline
Software Engineer
AKA: Addi's and Georgie's Dad
FRC #1629 (GaCo)
Team Role: Parent
gvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond repute
Re: [WindRiver]Creating a fresh buildable project
Originally Posted by SuperBK View Post
If I copy a project using windows explorer, how can I get that project to show up in workbench?
The solution is never use Windows explorer to manipulate Workbench projects or project files.
Use the Workbench Project Explorer instead.
Someone else has already described how to Import projects that are not already in your Workspace.
If you want to make a copy of a project that already exists in your workspace:
1) in the Project Explorer, right-click the project and select Copy in the pop-up context menu
2) in the Project Explorer, right-click in the white space and select Paste in the pop-up context menu -- this will pop up a Copy Project dialog box
3) in the Copy Project Dialog, type in the name you want for the copied project -- the default name will be "Copy of <whatever>" just like in Windows Explorer.
(You can also click on the project (to highlight it) and then use CTRL-C to copy and CTRL-V to paste)
Note that either way, the Copy Project dialog will have "Use default location" checked by default -- leave it checked.
Robots never, ever, ever, ever break -- The Robot Repairman (Backyardigans)
Windriver - Cannot Create New Example Project Aaron S C/C++ 6 01-19-2010 09:25 PM
help:Downloading the project in windriver mahmosh C/C++ 5 01-10-2009 10:08 AM
Creating new MPLab Project Mike Programming 4 01-15-2006 02:26 PM
Buildable Bridge? archiver 2001 0 06-24-2002 01:18 AM
Fresh from the forum Ken Leung CD Forum Support 3 01-15-2002 10:22 PM
