Go to Post Yes indeed... ten years ago tomorrow, those famous words "water game" were first mentioned on Chief Delphi! Oh, how things have and have not changed... - bduddy [more]
Unread 30-01-2010, 09:29
whatabouteve whatabouteve is offline
AKA: Dean Keithly
FRC #0245 (Adambots)
whatabouteve is an unknown quantity at this point
C++ Catastrophic error in libs compiling
Our team is having trouble compiling code. It always returns the error message in short
there is 1 catostrophic error 1st line #include "accelerometer.h"
if i were to delete the 1st line of sample code i get another error on the second line wiuth the exact same thing.
I would guess that we are missing some makefile.
but after downloading the wpi library several times, it still gives us the same error.
I am at a loss.
Please help!
Unread 30-01-2010, 09:37
gvarndell's Avatar
gvarndell gvarndell is offline
Software Engineer
AKA: Addi's and Georgie's Dad
FRC #1629 (GaCo)
Team Role: Parent
gvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond repute
Re: C++ Catastrophic error in libs compiling
Please post C++ questions/problems in the C++ sub-forum.
You need to:
1) describe exactly what you did to "compile the code".
2) tell us what "it" is when you write "It always returns the error message"
3) show (paste it in your post) the exact error.
Robots never, ever, ever, ever break -- The Robot Repairman (Backyardigans)
Unread 30-01-2010, 09:43
pafwl pafwl is offline
Franciose
AKA: Frank Larkin
FRC #0272 (Cyber Crusaders)
pafwl has much to be proud ofpafwl has much to be proud ofpafwl has much to be proud ofpafwl has much to be proud ofpafwl has much to be proud ofpafwl has much to be proud ofpafwl has much to be proud ofpafwl has much to be proud ofpafwl has much to be proud ofpafwl has much to be proud of
Check the code that is just before the .h file. These are all read in in the order you put them in your code. Look for a character that shoudn not be there either in the code just before the .h or in the previous .h.
Unread 30-01-2010, 10:17
AKA: Dean Keithly
1.we use windriver so the program automatically compiles when you hit build project.
2. windriver always returns an error message
3.this is a different computer that we don't program on.
the error is as i can best descride it.
in the build of "project file location/AnalogChannel.cpp" line 7 catastrophic error (etoa:4005): could not open source file "CAnalogChannel.h"
Note: this was after deleting the accelerometer error. this is the second program in the file list after accelerometer. The same thing occured with CAccelerometer.cpp
thank you
Unread 30-01-2010, 10:48
AKA: Dean Keithly
we are presently making sure we have all the updates.
i do not believe this is the issue but it needs to be done so we are doing it.
Unread 30-01-2010, 11:12
gvarndell's Avatar
Software Engineer
FRC #1629 (GaCo)
Team Role: Parent
It would save us both time if you could post a screen shot after the error has occurred.
Can't you take a screen shot and put it on a USB memory stick and post it?
If for some reason you can't post it, email it to gvarndell@hotmail.com.
Unread 30-01-2010, 11:43
AKA: Dean Keithly
okay i found the problem... for now. we got the crio imaged properly and now have a blinking light.
hurrah!
we'll face the other problem later but i think it involves another update.
Unread 30-01-2010, 11:48
gvarndell's Avatar
Software Engineer
FRC #1629 (GaCo)
Team Role: Parent
That's great.
The forums are more useful to everyone if we all give back to them as much as we expect to gain from them.
Please consider posting an explanation of how you solved the problem.
Unread 30-01-2010, 12:10
AKA: Dean Keithly
we didn't really find the solution we just got on the map as far as programming is concerned.
i'll post something later about how we got to getting code on the robot that works.
Catastrophic error agough C/C++ 3 24-01-2009 15:36
Compiling error AdamHeard Programming 2 30-01-2008 09:57
Compiling Error DustinB_3 Programming 1 12-02-2007 18:06
wierd compiling error Joohoo Programming 1 08-02-2007 21:32
Error when compiling paulcd2000 Programming 2 21-01-2007 14:05
