Re: How do you run Driver Station on the Developer Account?
Thanks to everyone who answered my question but I would like to clarify. Our specific problem is that we are unable to deploy and run code in the developer account without having to use the Driver Station app. We would like to run and debug the code from the front panel of main.vi. Is it possible to do this? Your assistance on this matter is greatly appreciated. |
Not sure if this is an option for you or not ... but my team uses a seperate laptop PC for development ... and mostly leave the DS/Classmate alone.
Normally, we tend to leave the Classmate DriverStation logged in as Driver, with a custom dashboard and the DS software running. We develop and deploy from our development laptop, allowing us to use the VI front-panels to debug and troubleshoot from the development laptop. We only need to touch the classmate if/when we tweak our custom dashboard, or to enable/disable the bot. Otherwise, most of our activity is at the dev laptop. If that's not an option for you, and you only have the Classmate PC, then your answer is already posted above. Login as Developer, and startup the DriverStation software from the start menu. |
| How to run dashboard project on driver station | baronep | Programming | 1 | 18-01-2010 14:58 |
| Log out of Developer to use DRIVER STATION? | JimC2550 | NI LabVIEW | 3 | 17-01-2010 22:01 |
| 2010 Driver Station Netbook Driver Account and Java | joshholat | FRC Control System | 2 | 10-01-2010 15:04 |
| How do you run the pneumatics through the CRio w/o using the Jaguars and the Spikes | brreadd | Pneumatics | 3 | 20-11-2009 15:35 |
| How sensitive are the driver station digital inputs? | FRC4ME | FRC Control System | 4 | 17-02-2009 20:26 |
